1966 monaco gas tank
Old Jul 4, 2008 | 07:17 PM
Monacoman's Avatar
there are 3 places for lines to exit mine only had 2 used could someone tell me what each is hooked up to cause my car doesn't get fuel and gas gauge does not work, not sure which goes where
Old Jul 5, 2008 | 06:37 AM
Monacoman's Avatar
i believe its only got a mechanical fuel pump at the motor i inspected it seems ok but the tank leaks out of the unused hole so i'm thinking because its so old could be a pressure issue since it only uses about 5 psi to run the car
Originally Posted by Doc
Gas not coming out and the fuel gauge not working are probably two diff issues. I would suggest taking the sending unit out and eye-balling it. The sending unit should come apart.
Old Jul 6, 2008 | 06:51 PM
Monacoman's Avatar
i fixed the no gas to carb problem but \gas gauge doesnt work and one of the outlets on the tank is unused, secondly car wont start i filled the carb with gas it ran till that dried but wont take gas through the needle and fill up the float:S
I am not following you.
68camperspecial
Jul 25, 2009 07:15 AM
bigsho
Jul 8, 2009 06:40 PM
8287rams
May 3, 2009 06:45 AM
71RR08
Aug 25, 2008 08:40 PM
Monacoman
Jul 5, 2008 11:15 AM
