View Single Post
Old 08-11-2008, 11:11 PM   #4 (permalink)
chlngr1970
Member
chlngr1970's Avatar
There should be two straps that hold the drive shaft to the rear pinion shaft. These are two straps that are helds on by two bolts each.
The green shaft bottom left is the drive shaft, the blue part it attatches to is the pinnion shaft. The strapps should be on the pinnion shaft side around the U-Joint. With those straps off, you should be able to pull the drive shaft foreward enough to get it out, and drop it down. Then you just slide it out of the tranny.
j
chlngr1970 is offline   Reply With Quote
