Go Back   Mopar Forums > GENERAL > Do-It-yourself Section
Thread Tools Display Modes
Old 08-26-2008, 08:52 AM   #1 (permalink)
TALudwick
TALudwick
Question Need Help with 86 Horizon 2.2
I have a 1986 Plymouth Horizon (Auto, with AC) with a 2.2 4 cyl in it. The following things have just been done to the car: New Cap, Rotor, Wires, plugs, Rebuilt Carb, Replaced all Vacuum Hoses, Timed and set Idle Mixture best I could. It seems to run alright from 1200 rpm on up, but I can't get it to idle right. It should idle at 900 but the best I have been able to do is 1000-1200 without it dying. At low rpms, it acts like someone is briefly disconecting power to the ignition at really short intervals. Could anyone give me any insight of what might be causing this?
Regards,
Tony
TALudwick is offline   Reply With Quote
Old 08-26-2008, 09:33 AM   #2 (permalink)
Commando
Senior Member
Commando's Avatar
Have you tried adjusting the carb?
Commando is offline   Reply With Quote
Old 08-26-2008, 11:58 AM   #3 (permalink)
TALudwick
TALudwick
Quote:
Thanks for the reply.
Yes, I adjusted the idle as low as I could get it (100-1200) without dying. Then I adjusted the timing to spec (10 deg btdc). Then I adjusted the idle mixture until I acheived the best vacuum that I could (approx 20). Still can't get it to idle smoothly at spec (900). Idle is sporadic between 1000-1200 and it acts like someone is briefly disconecting power to the ignition at really short intervals. The engine pulses or lopes.
Old 08-26-2008, 04:58 PM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Any codes ?
Doc is offline   Reply With Quote
Old 08-27-2008, 04:30 PM   #5 (permalink)
ef8340
Senior Member
ef8340's Avatar
what about the choke? maybe sticking
ef8340 is offline   Reply With Quote
Old 08-27-2008, 05:44 PM   #6 (permalink)
challenger
challenger's Avatar
Send a message via Yahoo to challenger
TALudwick do you have a meter with rpm readings on it ? or some one you no have one
challenger is offline   Reply With Quote
Old 08-28-2008, 07:44 AM   #7 (permalink)
TALudwick
TALudwick
Thanks Doc, ef8340 and challenger for replying.
Doc asked "Any codes ?":
I don't know if there are any codes because I don't have a computer to hook up to it yet. There is no check engine light lit, but I don't know if this vehical has one.
ef8340 asked "what about the choke? maybe sticking":
Choke is working as it should.
challenger asked "TALudwick do you have a meter with rpm readings on it ? or some one you no have one":
Yes I used a timing light and a tach/dwell meter to try and get the timing and idle set properly.
I am going to try spraying some carb cleaner around the manifold gasket with the engine running to see if I can detect any vacuum leaks there, because I have eliminated them everywhere else. I even clogged the brake booster vacuum line to eliminate the possibility of a leaky booster or bad HVAC components. I also plan to do a compression test. My wife was telling me that Jiffy Lube will check for codes free when you get an oil change, so I will probably try that too.
I will keep you guys posted on the results. Thanks for your input.
Regards,
Tony
Old 08-28-2008, 10:37 AM   #8 (permalink)
richinny
Senior Member
the rubber isolator under the carb is a know problem for vacuum leaks. was that changed?
richinny is offline   Reply With Quote
Old 08-28-2008, 12:42 PM   #9 (permalink)
Commando
Senior Member
Commando's Avatar
Quote:
What is that?
I believe I have a vacuum leak as well, and I sprayed all the lines and got no response, and am looking for any other culprits.
Old 08-28-2008, 07:15 PM   #10 (permalink)
richinny
Senior Member
please forgive me if my information is dated but early models used a combination rubber gasket/motor mount under the carb that often leaked. do you have something like that in you car?
Old 08-28-2008, 09:28 PM   #11 (permalink)
Doc
MasterDebater
Doc's Avatar
GOOD CALL rich .... I had an 81 car with a 1.7 that had that prob.
Old 08-29-2008, 05:02 AM   #12 (permalink)
Commando
Senior Member
Commando's Avatar
Oh ok, I believe I just have a regular gasket on there, but that still could be my problem, hopefully get to check it out later.
Old 08-29-2008, 05:32 AM   #13 (permalink)
richinny
Senior Member
Quote:
i worked at a dealership.we sold a LOT of them!
Old 08-30-2008, 02:54 AM   #14 (permalink)
Doc
MasterDebater
Doc's Avatar
C.... what is there is either a rubber sandwich gasket OR a solid alum one. The alum one is TUFF on a carb..... as I recall.
Old 08-30-2008, 05:26 AM   #15 (permalink)
Commando
Senior Member
Commando's Avatar
Oh ok, I haven't looked at it in a while, hoping its in the carb or intake area, as I tried the hoses. Any other major causes of vacuum leaks?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help With 86 Horizon 2.2 TALudwick K-Cars 1 08-26-2008 04:56 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
