HELP.. someone pulled my DIST caps off
Old Aug 22, 2008 | 09:07 PM
Commando's Avatar
I assume that it must be the wires, as the cap only goes on one way.
Old Aug 23, 2008 | 06:07 AM
ef8340's Avatar
Senior Member
remove no.1 plug and bump the ignition while using your thumb to cover the plug hole when the comp. blows your thumb off the hole that should be where no.1 is on your distributer check on your timing mark on the balancer to see if the line is close to the marks when everything is lined up wire acording to the firing order no. casted onto your intake
98 SNAKE EATER
Apr 16, 2013 04:45 PM
Judgester
Oct 5, 2010 05:42 AM
deadkelly
Aug 9, 2009 08:44 PM
cyclone2321
Aug 2, 2009 08:25 PM
grahamrw2
Jan 16, 2008 03:52 PM
