Small Block Exhaust Manifold Bolts & Washers
Old 09-24-2010, 08:56 PM
Duster_n00b's Avatar
I would like to know if you need "conical" washers for the exhaust bolts? Or can their be a subsitute?
Thanks!
- Mopar 360 Small block
Old 09-24-2010, 11:17 PM
A.K.A Bob Dodge
1966sportfury's Avatar
you can use lock washers, flat washers. ive never seen conical washers for exaust
Old 09-29-2010, 04:12 AM
Crazy4Carz.Com's Avatar
Originally Posted by mr.power
They are used on the end studs only. they are to pull down on the manifold away from the hole where there is studs. they are to suppose to stop the manifold from cracking or stud Shear when expanding and contracting. After many heat cycles the manifold will shrink. Ask anyone making power with a diesel. Our cummins sheared the end bolts off from the manifold shrinking. We replaced it with a two piece manifold from BD Diesel. They make these just for this reason. $400.00 plus and they sell a **** load. The dealer got us another factory one through warantee. It shrank at least a 1/2 inch end to end. Check out the holes in the ends of your manifold. They are larger in diameter for this reason. If you would put a flat washer on the end studs they could be sunk into the bigger holes preventing movement resulting in a sheared stud. Or a weak one that snaps when yo go to remove the nut. This washer is not a total cure but it helps. Now every one will come up with a reason why this is wrong. But this is the only reason for the washers. Don't use them I don't care . I remove alot of these studs for people. I will start a thread on easy stud removal
Thanks I learned something today.
Old 09-29-2010, 09:02 AM
A.K.A Bob Dodge
i didnt know they were called conical washers, the 1/4 inch (or so) thick ones,
JETBLU
05-01-2015 04:05 PM
CudaBob
12-17-2014 08:38 PM
snowtrooper1966
11-20-2013 06:39 PM
pipdog69
03-13-2012 11:01 PM
jar84203
01-02-2010 08:07 PM
Quick Reply: Small Block Exhaust Manifold Bolts & Washers
