Will 360 Magnum bock and heads bolt to my 72 cuda with 904 transmission?
I was going to rebuild my 318 cuda, but I got one heck of a great deal on a Magnum 360 short block (crank, pistons, etc.) and even the Magnum 2.02" valved heads. I hear they flow some good numbers.
I am pretty sure the answer is yes to my install question, but I am wondering what issues I will encounter. I think I read that motor mounts needs modification. Any details there? Bolt pattern should be fine to 904, and there is a flywheel with the block, so that covers balancing, right?
Anything else I am missing?
Any cam or build suggestions for a slightly choppy idle?
I have a Holley dual feed 650 for it.
I am using the camquest6 program, and 420hp is coming up pretty easily with those specs.
Amazing.
Glad I did not **** with the 318.
Thanks all.
I will keep you posted on the build.
-cudaracer
Amazing.
Thanks all.
-cudaracer
Depending on year and type of converter may not be compatible. Hydraulic lock-ups have a different trans input shaft. The bellhousing will need notching for the crank sensor if used.
Laura Cullen Reynolds
04-22-2024 03:24 AM
norcalitwin26
06-05-2014 02:16 PM
dpmalibu
08-03-2013 06:05 PM
