239 V6 to V8 swap help..
Old 10-05-2012, 10:14 AM
my89mopar's Avatar
Question 239 V6 to V8 swap help..
Hows everyone doing? New to the forum and new to the Mopar scene as well. Anyway, I have a couple of questions about swapping my 239 v6 to a larger v8. I know the 239, 318, and 360, are all similar engines but at the same time have their differences. If I was to change to the bigger 318 or 360 from the 239 what kind of modifications am I going to have to do to the frame and the engine and trans mounts? Are the transmissions the same or am I going to need an upgraded tranny as well? Also am I going to have to modify the suspension any since essentially I will be adding more torque and power? And will an airbag suspension work if I do?
Have only had my truck for 3 weeks now so Im learning more about it everyday. It is 2wd and it has drum brakes on the front and rear. Am I going to have to upgrade to disc brakes in the front? I already think I am so I guess Im just looking for confirmation on if this is a good idea or not..
All help would be appreciated..thanks alot..
Peace.
Old 10-05-2012, 01:15 PM
What is the vehicle?
You should upgrade the tranny when you upgrade the motor as the trannies that come behind the V6 motors are not that strong. Otherwise, you'll need a radiator and some wiring. It really depends on the vehicle though. And yes you should upgrade to disc front brakes at least. You may need to upgrade the rear axle too.
Old 10-05-2012, 02:08 PM
Sell your currant truck and buy one with the V8.
You need a motor & Trans, new drive shaft, maybe new rear end
Radiator, motor mounts ??, exhaust, disk brakes, computer.
What year is it that it still has front drum brakes
Old 10-06-2012, 02:29 AM
The 239 came out around 1987. Everything should have disc front brakes.
Gorts 5th (11-05-2012)
Old 10-07-2012, 07:59 PM
my89mopar's Avatar
The vehicle is a 89 Dodge D150 pickup.
Old 10-07-2012, 08:03 PM
my89mopar's Avatar
Lol..yea I guess selling it and buying a new one would be the easy way out but I wanted a project and I got it for a good price. The vehicle is a 1989 D150 pickup. Its got a solid body..like one easily pulled dent and thats about it. Its an old gov't vehicle( I live near DC) so it was well maintained. I just want to turn up the volume on it a little bit and make it a street rod.
Old 10-07-2012, 08:43 PM
You can do anything with enough money. Make a Little Red Express truck clone
Old 10-07-2012, 10:21 PM
78doubleR's Avatar
Motor swaps are simple. You can use the factory v6 mounts and trans if you'd like but that trans wont last long behind a v8. Its pretty much plug and play.
Old 10-14-2012, 08:41 AM
my89mopar's Avatar
Thanks 78doubleR thats all I needed to hear. I was planning on doing the engine and trans at the same time anyway. What about the brakes? Updating the calipers..rotors..etc..are those just plug and play also? Kinda just wanna know some of the parts I might need so I dont have to make 100 trips to the parts store.
Old 10-15-2012, 12:15 PM
78doubleR's Avatar
As long as they are off the same vehicle as your i don't see why they wouldn't work.
Old 10-15-2012, 02:30 PM
I'd look into a 1 ton brake setup before buying any brakes. If they will fit your vehicle, I'd say do it.
As far as the swap goes, you should be able to pick up a BB motor/tranny for about the same price as a small block. The trucks have so much space in them too that you'll have no problem dropping it in.
Old 11-05-2012, 12:02 AM
my89mopar's Avatar
What do you all think about switching to diesel? Maybe a 4bt? Is it worth the money?
Old 11-05-2012, 02:43 AM
Only reason I would do that swap is if the truck were being used as a tow vehicle or if I wanted to up the "cool factor".
If you are looking for performance, I don't see that coming from a 4tb motor. Now a 6tb cummins..... that could be fun.
my89mopar (11-05-2012)
Old 11-05-2012, 04:26 AM
Gorts 5th's Avatar
Question
did you say that this 89 D150 has 4 wheel drum brakes thats a new one two me
Old 11-05-2012, 01:32 PM
my89mopar's Avatar
I was wrong about the drum brakes. That was a post before you proof read error.
Old 11-05-2012, 01:35 PM
my89mopar's Avatar
I might want to up the cool factor..lol. Thats why you do engine swaps isnt it? Lol. I might look into the 6bt. Never owned a diesel so I dont know what to expect. I do want to be abke to tow cars and trailers with ease though.
Old 11-05-2012, 01:54 PM
1T brakes will be 8 lug !!
Old 11-05-2012, 02:57 PM
Gorts 5th's Avatar
Smile
i know diesels especial the Cummings is one powerful motor but i never liked the bleching out soot and smell and they still diesel not roar. lol
well at least its not made out of plastic like the new ford carbon fiber diesels
Old 11-05-2012, 04:03 PM
A well build LA motor, Magnum or even BB will allow you to tow a vehicle with the truck.
TVLynn - I know that 1ton brakes are 8 lug. This would be a perfect time for my89mopar to upgrade the rear axle to a 3/4 ot 1 ton D60 rear axle and then swap on a set of disc brakes and 76-78 Cadillac Eldorado rear calipers since they have the intergraded e-brake cable bracket. Talk about stopping power for all that torque and HP.
Old 12-15-2013, 08:29 PM
daisyjohn's Avatar
Honestly your best bet is probably to get a donor truck that’s got a good engine and Trans just to save yourself the trouble of having to get one part after another.
Old 12-15-2013, 08:45 PM
DodgeAddict's Avatar
That's exactly what I do You get everything right down to the correct bolts to do the job
Old 10-20-2020, 04:37 AM
pgalvan00's Avatar
Question v6 to v8?? $$$$
hello all, new member here... question: i have a 2014 ram 1500 v6 in great shape, low miles... but I would like to put a v8 engine instead. Is this an expensive job? What parts etc are needed... obviously not a gear head so not sure what all is involved. any help and insight is appreciated... i hope somebody reads this question lol
Route66rider
12-05-2012 05:17 AM
notta _mech
09-13-2011 09:42 AM
Daytona45
01-24-2009 04:18 PM
1982dodgeram
11-23-2008 02:42 AM
wcturn
08-11-2008 06:59 AM
Quick Reply: 239 V6 to V8 swap help..
