440 Electronic Ignition Conversion- cutting out
Old 04-08-2009, 06:01 AM
Commando's Avatar
Welcome to the forum.
I assume you converted from a points setup?
Did you replace the distributor?
Is the vacuum line for the advance in the carb plugged?
Old 04-08-2009, 09:57 AM
Apollo's Avatar
Double check your timing and if all else fails, re-install your dist. Sounds like your timing might be off. Also might want to check the carb with with a vac meter, check air/fuel mix. Volt regulator as well. . .
67gtxclone
10-05-2010 06:07 PM
heminate
10-01-2009 02:10 PM
Aspen
09-01-2009 08:10 PM
64fury
07-08-2009 12:43 PM
Duster703404
11-11-2008 06:40 PM
Quick Reply: 440 Electronic Ignition Conversion- cutting out
