Thrust Washers
Old 01-02-2010, 03:29 PM
Member
jar84203's Avatar
Thrust Washers
I was interested in tightening the play in the differential of a 66 Coronet and was wondering if anyone knew where to get the side gear thrust washers in various sizes to do this? Or do they even exist? Thanks.
Old 01-02-2010, 06:56 PM
theomahamoparguy's Avatar
rear end shims
the 8 3/4 doen not use side thrust washers for the ring gear. It has threaded adjusters. Some shims may be used for the pinion gear to set its depth. Randy's ring and pinion, www.ringpinion.com has everything you could need. It may be possible that your pinion nut has loosened. Usually the gears do not go out of adjustment, Gears may be toast.
Old 01-02-2010, 08:07 PM
Member
jar84203's Avatar
I was actually hoping to tighten up the play between the side and spider gears.
69Bird
05-27-2014 04:18 AM
68 Sat
03-03-2011 06:48 PM
Duster_n00b
09-29-2010 11:16 AM
68 Sat
11-07-2009 07:14 PM
Quick Reply: Thrust Washers
