1965 880 Custom (Parts and Tips)
So i have had this car for a couple years now and havent got much done with it. One major thing holding me back is that i cant find a radiator for it without getting a custom one done ($$$$$$). And for whatever reason it wont start anymore. Just getting a click somewhere on the driverside of the fire wall. Battery, Starter, Starter Relay are all good. Wireing looks to be fine too.
Nope the battery is fine. I have an optima red top and a yellow top. The yellow was in there and i swapped it out for the red in my other truck. the yellow started fine in my truck once i installed it. Although the red brought me that click, the yellow brought me the same click but i would have to pull the terminals to get it again. where as with the red i get it every time
What the hell is going on?
Ok lemme fill you in. The voltage regulator didnt do anything but make it look a little better under the hood. one less rusty part. I changed the ignition switch and it started turning over. didnt start because by the time it had fuel threw the filter a wire started melting and smoking. i fixed the wire but now smoke is coming from under the dash by the new ignition switch. I pulled it to check it out but not sure what to do now. DAMNIT!!!!!
