68 Fury 2 disc brakes
I have a 68 Fury 2 ex highway patrol car and it is equipped with front disc brakes. I am trying to find some replacement brake pads and I was wondering if anyone knew if they still make them and where I may find some. Dr. Mopar in Texas informed me that the 65-68 c-body brake parts were interchangable but I'm still struggling.
Thanks Rob |
i did a quick search and found no listing for calipers for that model. i had disk brakes on a 68 chrysler 300. the parts might be the same. i'll throw in that when i replaced the master cylinder that the correct master for my car was a DRUM brake master with the equal sized compartments. i believe it was the first year chrysler offered disks on that model.
I found a listing for the brake pads, what engine is in the car so I can make sure I find the correct ones.
I FOUND SOME!!! Thanks for the help!!
master cylinder
Originally Posted by richinny
(Post 9889)
it was the exact replacement to what was in it. i have no idea which proportioning valve was in it.
calipers
I just took the caliper apart and found out that the rubber boot around the piston is leaking fluid and I was woundering if you, or anybody else, new a quick fix to this problem. I know you said you have disc brakes on your 68 300 and the parts should be the same. Have you had to replace the calipers or have them rebuilt????
If you can find a parts store that sells the calipers, you may be able to get them loaded with the pads as well.
