HELP!!!
Old 07-23-2009, 11:20 AM
Junior Member
Kinger1421's Avatar
Exclamation HELP!!!
So I have a 65 Dodge 880 Custom with a 6.3l 383! I was driving it in January of this year, left it to sit untill about mid june. Now its not starting at all. I turn the ignition and all i get is a click like the starter is popping but not spinning. So i take the starter to get tested and it passes. Pop and spin! Its got a new Optima Yellow top in it so its getting plenty of power. Also every time i turn the ignition and get the pop i have to pull the neg bat line and put it on to get the same result (just a click). Any suggestions????
Old 07-23-2009, 11:27 AM
Polaradude's Avatar
So you are getting the solenoid click and that's it ?
Check the main cable to the starter from the battery.
Check the grounds, battery to block, block to body or whatever your set up may be.
Let us know.
Old 07-23-2009, 12:09 PM
Junior Member
Kinger1421's Avatar
All the connections are good, tight and unblocked. I made sure to check em when i put the starter back on!
Old 07-23-2009, 01:55 PM
Polaradude's Avatar
So when you turn the key all you are getting is the solenoid click ?
We need a little more info.
Old 07-23-2009, 02:31 PM
Junior Member
Kinger1421's Avatar
All i get is a click. Then if i try to turn it over again i dont get anything. So i pull the neg bat cable, and reconnect it then when i attempt to start it again i only get another click. I cant seem to get past this effin click.
Old 07-23-2009, 03:23 PM
scotts74birds's Avatar
I'm dum but have you tried to turn the engine by hand? When you try to start and hold the key, does the pos bat cable heat-up?
Old 07-23-2009, 03:29 PM
Junior Member
Kinger1421's Avatar
Yes even a lil smoke from the terminal!
Old 07-23-2009, 03:56 PM
Try turning the engine by hand.
Old 07-23-2009, 03:59 PM
Junior Member
Kinger1421's Avatar
You mean at the flywheel?
Old 07-23-2009, 04:05 PM
probably with a socket and breaker bar at the bolt on the front of the crank. Should be some resistance, but you shouldnt have to reef or stand on it. clockwise while facing the motor.
Old 07-23-2009, 04:11 PM
Junior Member
Kinger1421's Avatar
Sounds pretty effin hazardous but ill give it a shot. lemme know if you come up with anything else. i could use all the brainstorming i can get!
Old 07-23-2009, 04:24 PM
Well ya dont do it while its running! but I didnt think that was an issue right now, lol. turn the key off if you are worried about kick-starting.
Old 07-23-2009, 04:37 PM
Junior Member
Kinger1421's Avatar
O running is def a problem so i wouldnt even put the key in it anyway! Soon as i score a Socket that size ima give it a shot
Old 07-23-2009, 06:14 PM
Junior Member
Kinger1421's Avatar
Ok so i replaced the starter relay and its cranking over!!!!!! I havent tried to start it fully because i am noticing a small amount of smoke coming from the neg terminal! What the hell is that about???
Old 07-23-2009, 06:31 PM
Neg terminal at the battery? If the connection is tight, one should look at the strands of the cable going into the clamp. It can become corroded and only a few strands may actually be intact, is there alot of green corrosion on the strands? Voltage=pressure. It does not take much to cause resistance in a 12v circuit. So I guess it was the starter relay? Or was it from cleaning the contacts on the wires while changing the relay?
Old 07-23-2009, 06:34 PM
Junior Member
Kinger1421's Avatar
it was the starter relay. now i have a clog somewhere in the fuel line like i did when i first picked this thing up.
Old 07-23-2009, 06:43 PM
I am happy for you.
