Neutral Safety Switch
Old 08-28-2013, 09:39 PM
dsikkema's Avatar
Can someone please tell me where the neutral safety switch is located on a 1968 Plymouth Fury III?
It is starting in all gears so I guess this is the problem?
Thanks
Old 08-28-2013, 09:46 PM
It's a three wire switch on the transmission near the shift lever
Old 08-29-2013, 05:15 AM
Not in 1968. It is a single wire switch. Someone could have it jumped out to ground. Your black wire runs to the bottom of the starter relay. Trace it and see where it goes. If someone grounded it that will be your problem.
Old 08-29-2013, 12:17 PM
I thought they changed in 68 ?? My mistake.
Old 08-29-2013, 02:09 PM
moe7404's Avatar
my 1967 chrysler / imperial factory service manual show a single wire neutral start switch post. the 1967 Dart / Coronet / Charger book shows the same. sorry dont have a 1968 book handy.
Old 08-29-2013, 03:17 PM
unclehulka's Avatar
I had heard that there was a mid-year change from a 1 to 3 prong switch for model year 1968. I have an early build '68 Sport Fury Convertible and it has a single prong (for what it's worth).
Old 08-29-2013, 03:54 PM
moe7404's Avatar
i didnt know about the mid year change. but NOT surprised. many times i wish i had bought chrysler parts books.
Old 08-29-2013, 09:04 PM
dsikkema's Avatar
Thanks for the responses guys. this is my first time trying to fix a problem like this, so I need a bit of clarification. where is the starter relay located and where exactly should the black wire run to? do I need to take the steering column or anything apart to get to the neutral safety switch or fix this problem?
in your opinion is this likely to be the reason it is starting in all gears?
FYI build month is May 1968.
Thanks in advance.
Old 08-30-2013, 08:52 AM
All Mopar starter relays work the same until a very late change when an additional terminal was added. Stick cars up to '70 had three terminals, Stick cars 70 / later and all automatic cars have 4 terminals.
The great big stud / nut is the battery connection "junction" and is ALSO one contact of the relay switch
The smaller bare "square" screw is the second relay contact and goes to the starter solenoid
The one (on a stick) or two (auto) "push on" connectors are the relay coil
One of those, traditionally yellow, comes from the key "in start" through the bulkhead to either "push on" terminal
The remaining "push on" terminal goes down the firewall, over the top of the transmission, and to the neutral safety switch on the transmission. It grounds in park or neutral.
dsikkema (09-06-2013)
Arbiter343GS
10-31-2011 08:44 AM
Aaron.Albrecht
07-30-2011 10:24 AM
Derek77PW
07-16-2011 08:33 AM
Dave MoorePower
08-11-2008 05:59 AM
hemihead
03-18-2008 03:23 PM
Quick Reply: Neutral Safety Switch
