Neutral Switch 68
Old 02-26-2011, 01:20 AM
uwekoch's Avatar
Neutral Switch 68
My neutral switch is no more working, if i ground the wire the car will start.
Unfortunately it is the one prong version (early 68) which is harder to find. Can i use the trhree prong version , using only the pin for the starter relay or is the design (internally) different at all?
Thanks, Uwe
Old 02-26-2011, 05:40 AM
rdrunner1974's Avatar
switch
Is this for the 68 Chrysler 300? Is it on the trans or pedal linkage? More info is allways good to help you.
Old 02-26-2011, 06:20 AM
uwekoch's Avatar
It is for the 1968 Chrysler 300, the switch is in the transmission housing with one prong. The question is, if the easy available switch for the late 68 models and on can be used, even if the backuplight function is not used.
Old 02-26-2011, 07:55 AM
rexus31's Avatar
Thanks, Uwe
Hard to find? Came right up on an eBay search:
http://cgi.ebay.com/ebaymotors/MOPAR...s#ht_818wt_912
Old 02-26-2011, 12:21 PM
uwekoch's Avatar
Got it, thank's a lot!
Old 02-26-2011, 12:33 PM
rexus31's Avatar
No problem!
Old 02-26-2011, 02:46 PM
blue 68 gts's Avatar
http://cgi.ebay.com/ebaymotors/MOPAR...Q5fAccessories
In case you wanna save about $20 all in all.. This guy knows his transmission stuff.
Old 02-26-2011, 04:11 PM
rexus31's Avatar
True, they do know their stuff and I have bought from them before however, his are used. I'd rather pay a little extra and get a new one.
Old 02-26-2011, 06:04 PM
Yes, but most of these parts he has had for decades. You should see Pats garages.. FILLED with Torqueflites.
He built my trans, and I'd feel 100% safe running anything new or used from him.
Old 02-26-2011, 06:59 PM
rexus31's Avatar
Be that as it may, I personally would rather pay a little more for a new part, whatever it is. I've gotten burned too many times in the past with "like new" or "slightly used" parts.
Old 05-02-2011, 11:42 AM
ESPECIALLY electrical stuff...
Old 08-09-2012, 02:26 AM
MOD300's Avatar
G'Day,
I saw a question about your plastic side moulding clips... Iso I joined up to give you this website.
http://www.restorationspecialties.com
This is where I have located all the different clips for your 300
Arbiter343GS
10-31-2011 08:44 AM
Derek77PW
07-16-2011 08:33 AM
dorseyh
08-22-2009 10:27 PM
Dave MoorePower
08-11-2008 05:59 AM
hemihead
03-18-2008 03:23 PM
Quick Reply: Neutral Switch 68
