OEM intake manifold?
Old 01-12-2014, 05:06 AM
Mr onetwo's Avatar
Hey Guys, Can anyone tell me if a Mopar CASTING NUMBER, 1851898 intake would be any good to put on my 1968 Newport 383? One thing I would like to do before spring is to swap the 2bbl for a good 4bbl setup.I really don't have the money to spend on new stuff.What would be a good used carb to fit on this stock car?Are the old Carter AFB's any good or should I look for a used Holley?Also, what about a Carter Thermoquad #6-2472....there is one on Ebay for $50?
Attached Thumbnails OEM intake manifold?-_57.jpg   OEM intake manifold?-_57a.jpg
Old 01-12-2014, 05:36 AM
First that is not a Thermoquad manifold.. A good carter AVS carb would be great...Are you sure it is a 383 manifold?? Picture makes it look wide.
Old 01-12-2014, 06:39 AM
Mr onetwo's Avatar
I found a list that says it is from a 1959-60 383 4bbl. A later design might be better????
Old 01-12-2014, 07:19 AM
moe7404's Avatar
that is a 1959-1960 383-4 manifold. you might have trouble putting an A / C bracket on it. i am not sure but i think i have seen some manifolds that have a machined spot for the A / C bracket and some do not. but check it out. all so on that engine . the 2 bbl and 4 bbl use different pull cable and trans linkage. mostly the length. if you use a 2 bbl cable on 4 bbl it will bind up cause it isnt pulling stright. edit ; and the cable bracket is different. just check out a parts book.
Old 01-12-2014, 07:32 AM
I'm sure the intake will fit as long it is for a 383... The carb mounting flange might take a little work to figure out what will fit on it best....
And getting all the linkage alignment rite takes some attention. Like that was mentioned before...
Old 01-12-2014, 09:02 AM
Mr onetwo's Avatar
I think I found a better alternative.....casting no. 3512501 from a 1971 440-4.On Ebay for $60 OBO.
Attached Thumbnails OEM intake manifold?-705099430_o.jpg   OEM intake manifold?-705099453_o.jpg
Old 01-12-2014, 10:28 AM
moe7404's Avatar
looks like a 1971 only. and said to have amoung the best stock air flow. uses the squre bore bolt pattern. I.E. GOOD. but DO use anti-sieze compound on the choke heat stove bolts. just my idea.
Old 01-12-2014, 10:33 AM
YOU CAN NOT interchange "low block" and "raised block" intakes.
"Low blocks" are 361-383-400
"Raised blocks" are 413 -426 wedge, -440, and the oddball early long stroke 383
You have a "low block" you need 361-383-400 manifold
Mr onetwo (01-12-2014)
Old 01-12-2014, 12:30 PM
Mr onetwo's Avatar
Thank you....I was very confused on the 2 different 383 engines.The right manifold will be hard to find I think....anyone have one?Correct casting number is 2806301
Old 01-12-2014, 12:33 PM
Like 440 said...You cant use a 440 intake on a 383... It dose not fit...
Not hard to find... You just need one for the 361-383-400 Low Deck...
Old 01-24-2014, 03:55 PM
Mr onetwo's Avatar
Found a 2806301 locally for $40....thanks to all.
mrzods13
02-22-2014 08:37 AM
M1 Manifold
05-21-2009 02:23 PM
CantRamItDodgeIt91
05-10-2009 03:34 AM
lail1985
10-14-2008 10:31 AM
Quick Reply: OEM intake manifold?
