Plymouth Fury III Comando
Old 07-05-2010, 05:28 PM
DoctorWho's Avatar
Unhappy Plymouth Fury III Comando
I am new to the forum, I am working in a small Gas station / Automotive service station in Portland Oregon, I was given a 1967 Plymouth Fury III comando 2 door in pretty good shape, the engine needs a tune up, but runs ok for now, however, the tranny seems to need repair(s), in drive, it sits there unmoving until reved hard, then it creeps, and seems not to shift, it has reverse too.
It has a 383 engine and a 727 tranny, any advice ?
Old 07-05-2010, 05:51 PM
Polaradude's Avatar
Hey Doc, Welcome to the show.
Perhaps you have done this already but I have to ask, Have you checked the fluid level ?
Old 07-05-2010, 08:23 PM
DoctorWho's Avatar
Talking
That was the first thing I checked, it was not low, and it has not leaked.
Old 07-05-2010, 09:52 PM
A.K.A Bob Dodge
1966sportfury's Avatar
how does it smell or look? burnt. could be as simple a the filter needs changed or bands need adjusted,
Old 07-06-2010, 06:52 AM
Polaradude's Avatar
By no means am I suggesting you dont know what you're doing but I have seen people that dont know how to properly check a 727 fluid level.
If you check it in park you will get an incorrect reading on the stick as the torque converter doesnt fill when the tranny is in park. You must check it warm and in neutral. Also like Bob said check the fluid colour and smell and feel.
We'll get ya sorted out Doc. Keep us posted.
Old 07-06-2010, 07:13 AM
DoctorWho's Avatar
It was a good question, sometimes one forgets to check the simple things first like fluid levels and wire connections.
The tranny fluid is not burnt, but perhaps the filter is gummed up after so many years and who knows how many tins of tranny additives and other residues built up over time.
Old 07-06-2010, 07:26 AM
Polaradude's Avatar
Ok, cool. Had to ask.
My advice would be give her a tune up and we will go from there.
Old 07-06-2010, 07:33 AM
Polaradude's Avatar
Also "Fundamentals of Automatic Transmissions and Transaxles" from Chrysler and it is easy to comprehend and very thorough. It is available from the Chrysler Training Center. The number on it is TM-508A and the cost is about $10-$12. You won't find a better manual covering 904s, 727s or the new transaxles. You may want to check that out.
Old 07-06-2010, 03:35 PM
DoctorWho's Avatar
Cool thanks !
I will order that manual (TM-508A) from the local parts folks here....
thanks for the tip !!!!
Old 07-06-2010, 03:45 PM
DoctorWho's Avatar
Fat Rats ! I called Chrysler from the shop today and they did not know what I was talking about ! when I asked about the manual.....
Old 07-06-2010, 07:44 PM
Buffalojoe426's Avatar
There is another hope. I have the Torqueflite a-727 transmission handbook by Carl H. Munroe, it's what i used to rebuild my 727. I stand behind it. You can order it on Amazon. HPBooks-1399, that's whats on the bottom of the spine.
Old 07-06-2010, 10:58 PM
DoctorWho's Avatar
Easy enough, it may actually shape up with only a filter / fluid change and band adjustment, actually this car may only have less than 29,000 original miles on it, it had one original owner here in Oregon, was dealer serviced for years and sat unused for who knows how many years.........the guy died as he was pretty old when he bought it, it is not a "pretty car" the green paint is dull and horrible to look at, so no one gives it a second glance.....
Old 07-07-2010, 02:01 AM
Polaradude's Avatar
I'll send someone right over to pick up the ugly thing and get it out of your sight...lol
Old 07-07-2010, 08:29 AM
DoctorWho's Avatar
What tranny fluid should I use in this tranny for best results ? I am sure by now it may have a mix/blend of types....
Dexron II or type F ?
Old 07-07-2010, 10:35 AM
A.K.A Bob Dodge
dextron/ 3
Old 07-07-2010, 03:26 PM
DoctorWho's Avatar
What is the diff between Dexron II and III ? as it relates to the 1967 727 ?
Is type F better ?
Tom Hand says type F sometimes gives firmer shifts....
Old 07-07-2010, 03:28 PM
A.K.A Bob Dodge
i really dont know that, i know dexron 2 works well also, ive used dex2 alot, and 3 i didnt have a prob with any
Old 07-08-2010, 06:25 AM
rexus31's Avatar
I put Type F in my rebuilt 727 with no issues at all. From what I've read online, Type F gives a little firmer shifts.
Old 07-08-2010, 02:20 PM
DoctorWho's Avatar
I heard putting in a separate tranny fluid cooler was a good idea, so if a leak develops, antifreeze will not get into the tranny, does anyone know of a good model external cooler to use ?
Old 07-09-2010, 06:16 PM
scotts74birds's Avatar
Please be careful when google-ing "tranny fluid" or "blown tranny"! You wont like what you find!! LOL!!
Old 07-11-2010, 09:49 AM
DoctorWho's Avatar
very true
Old 07-11-2010, 10:02 AM
samuelcosmo76's Avatar
HAHAHAHA
Old 07-11-2010, 12:23 PM
blue 68 gts's Avatar
I used Dextron 3... Thats what my transmission builder (Pat Blais) recommends. No problems with shifting at all...
Old 07-18-2010, 10:40 PM
  #24
Junior Member
betweentheframe's Avatar
I just got a 65 fury II with 24k and have the same problem
I just picked up a 65 fury II 383 commando 2bl with 24k original miles, hadnt been tabbed scince 74, been in a dark garage so is in mint condition.
Got the car running and drives in reverse, but no forward, I had driven it like 6 locks with it badly slipping/not grabbing or hooking up, but it hooks up fine in reverse, so not torque converter.
just changed the fluid and filter including draining the torque converter and still no change.
before I yard this thing out, should I have it flushed, or just puull her out and have her rebuilt, it doesnt go in 1st or 2nd either.
adjusted the forward band and it was right where it needed to be.
Old 07-19-2010, 07:23 PM
  #25
that's a damn nice dart, blue 68! DAMN nice!
type f is for ford vehicles, and i have been told never to use it in chrysler applications, but i cannot honestly say why. i'd never heard the 'firmer shifts' bit.
Old 10-01-2010, 02:02 PM
  #26
sportfury65's Avatar
Type F will definitely give firmer shifts but it has a grittier texture that will wear out the clutches and bands sooner. BEEN THERE, DONE THAT 30 YEARS AGO!!!
Old 10-04-2010, 02:09 PM
  #27
haha good to know. i've always stuck with dex III and never had an issue at all.
Old 07-21-2011, 02:49 PM
  #28
DoctorWho's Avatar
Update to this thread:
I was given a 727 tranny from a 1967 Newport, runs well now.
Old 07-21-2011, 02:50 PM
  #29
Hey cool! Can't beat that!
Old 11-11-2011, 02:55 PM
  #30
bboogieart's Avatar
Dr, ... Who keeps giving you these things?
I want to know some one like that.
And Rexus, shame on you, type f is not origanal.
Quick Reply: Plymouth Fury III Comando
