Any Help Removing Heater Fan
Old 09-11-2012, 03:15 PM
gregsgs@yahoo.com's Avatar
Hi Everyone we its time to fix the heater fan. Can anyone tell me were to start or have a diagram of the parts. Its a 70 cuda with out AC I don't no were to start someone told me it very in hard to do. Any help would be GREAT thanks
Old 09-11-2012, 08:11 PM
moparted's Avatar
you have to remove the entire heater box assembly
Old 09-12-2012, 08:23 AM
Do you know were to start with that
Old 09-29-2012, 09:49 AM
Chryco Psycho's Avatar
drain the coolant , remove the heater hoses , remove the glove box liner , there is 1 hidden bolt insode the vent on the right side , it is a hook that holds the heater box up , loosen the bolt & carefully unhook it then undo the 3 - 7/16 nuts around the heater motor in the engine compartment & sldie the heater box back into the car now remove the vent & heat cables & remove entire heater box
kiwi
07-26-2011 09:39 AM
Cazbah362
06-12-2011 01:05 AM
mytracy
12-29-2010 08:20 PM
JLanzino
05-01-2009 06:58 PM
gilesie
07-14-2008 02:29 AM
Quick Reply: Any Help Removing Heater Fan
