SolidBushings.com
SolidBushings.com
They make like products that Firm Feel produces..I have not used them but others have...they are a cheaper alternative...
Mopar Applications
P/N: CPD001
Isolator Bushings for 73+ Bs, and ALL FJM and R bodies. These are made out of Solid 6061 Aluminum. Comes with 4 bushings, 4 heavy duty washers, 4 grade 8 bolts, and 4 lock washers. Aluminum parts are anodized black. Threadlocker is highly recommended when installing.$160 Set of Four, $15 shipping in the Continental US
P/N: CPD002
Torsion Bar Crossmember Bushings for 73+ B and R bodies. These are made out of Solid 6061 Aluminum. Comes with two upper and lower bushings, grade 8 bolts and washers. Aluminum parts are anodized black. Threadlocker highly recommended when installing.$50 Set of Two, $7 shipping in the Continental US
P/N: LBK001
Consists of the K-frame isolator bushings and Torsion Bar Crossmember Bushings. For 73+ B and R bodies. Save a couple dollars when ordering together!$195 for the set. $15 shipping in the Continental US
P/N: CPD003
Leaf Spring Pad Bushings for 73+ Bs and ALL FJM and R bodies. These put your rear end right on your leaf springs properly locating them. Made from mild steel and black oxide treated. Use these when you will be using stock style springs, stock rear end, but have completely eliminated the rear iso-clamp system. Also includes a new Grade 8 bolt & nut for your springs. You will need to provide your own U-bolts and lower (shock) plate. $25 per Pair. $5 shipping in the Continental US
P/N: CPD004
Leaf Spring Pad Bushings for 73+ Bs and ALL FJM and R bodies. These re-use your upper iso-clamp plate. Useful if you want to retain your rear sway bar/upper iso plate. These leave your rear end on your isoplate, and locates the iso plate directly onto your spring. Made from mild steel and black oxide treated. Also includes a new Grade 8 bolt & nut for your springs. You will need to provide your own U-bolts and lower (shock) plate. $25 per Pair. $5 Shipping in the Continental US
P/N: CPD005
Lower platefor 73+ Bs and ALL FJM and R bodies. These are generally used in conjunction with P/N CPD004. Water Jet cut from 3/16" mild steel and black oxide treated. Customer to provide their own U-bolts.$50 per Pair. $7 Shipping in the Continental US
P/N: REK001
Consists of CPD004 bushing and CPD005 lower plate.Save a couple dollars when ordering together! Customer still to provide their own U-bolts.$70 for the set. $10 shipping in the Continental US
http://www.solidbushings.com/catalog.html
Mopar Applications
P/N: CPD001
P/N: CPD002
P/N: LBK001
P/N: CPD003
P/N: CPD004
P/N: CPD005
P/N: REK001
