1970 power wagon
Old 04-22-2013, 04:38 PM
powerwagon70's Avatar
1970 power wagon
hi guys, i'm looking for a front drive shaft for a 1970 w200 can't find one anywhere. Also does anyone one know now if any other dodge shafts will fit it?
Old 04-23-2013, 02:28 AM
W200 is a 3/4 ton truck which means you probably have a HDD44 (same as the normal D44 - only difference is the axle tube size) front axle. Being a 1970, there is a chance that the front axle is a closed knuckle and if that's the case then then my next paragraph may not be true.
If you find another Dodge truck up till ~93 with the same drivetrain that is a W200/W250 (3/4 ton), then they should fit.
Do you know what size the yoke is on the axle? Also, do you know the size of the yoke on the t-case?
Old 05-09-2013, 09:33 PM
69 powerwagon's Avatar
try vintagepowerwagons.com they usually have the parts I'm looking for my 69 w200. I recommend getting their free catalog and a shop manual.
77powerwagon
12-25-2016 05:33 PM
cnskate
07-20-2009 07:11 PM
Scotteey
07-17-2009 08:47 PM
theaspenator
05-25-2008 09:44 AM
CAT-TECH
01-17-2008 06:33 PM
Quick Reply: 1970 power wagon
