Engine swap 318 to 360
Old 03-10-2010, 01:06 PM
Junior Member
SfloreS's Avatar
New to this stuff help is greatly appreciated !
I have a 67 D 200, 4 speed manual with a LA 318 a want to swap it with a LA 360. What problems may I run into if any? Are motor mounts the same?
Thanks for the input
Old 03-10-2010, 10:32 PM
theomahamoparguy's Avatar
yes the motor mounts will work but you may have to do some shimming with washers. Also, the 360 has external balance so you will have to deal with that. I guess you could weld the balance weight to the flywheel. Or get a 360 flywheel. other than those two things, it should be a fairly easy swap. You might try to use the same style of oil pan as far as the original sump location goes. [middle or rear]. you could use the 360 truck manifolds ( i had a 68 D 200 with a 318 and it had the 360 heads on it with the 360 truck exhaust manifolds from a 76 d 200).
Old 03-11-2010, 08:36 PM
Member
volaredon's Avatar
318>360 "yawn".
Old 03-19-2010, 01:38 AM
Sangetsu's Avatar
Yes, the 360 is an externally balanced engine, you'll need to find a flywheel from a 360 for the swap to work. I learned the hard way what happens if you use the wrong converter/flywheel in a swap.
Old 06-19-2010, 09:02 PM
chlngr1970's Avatar
One thing to remember about the 360/318, is the 360 has larger main journals, hence a larger front/rear main seal...hence a different pan. I don't know if this holds true for the truck, but the motor brackets are different for the 273/318, 340/360 A body. Just throwing that out there...
j
Old 06-19-2010, 10:16 PM
A.K.A Bob Dodge
1966sportfury's Avatar
j
not being a dick but the 273/318/318poly/340 are the same mounts 360 is the odd ball,
Old 06-20-2010, 05:51 AM
Senior Member
ef8340's Avatar
i just got done doing a 318 to 360 swap in my dart my 360 was a truck motor from a 89 ramcharger i have the rear sump oil pan and pick up tube and the motor mounts if your interested 60.00 bucks plus shipping
Terry
Old 06-20-2010, 05:56 AM
Senior Member
ef8340's Avatar
340 and 360 are the same the driver side mounting tabs on the block are closer together
Old 06-20-2010, 10:35 PM
A.K.A Bob Dodge
what! i musta been high (and i dont )when i had my 340, i swear they the same a the 318, well i apologize
Old 06-21-2010, 02:33 AM
I always thought that the LA motors (273-360) all used the same casting for the block and heads and it was just what was on the inside that made them all differ.
Only other thing that I know is different between the 273-340 motors and the 360 is that the 360 is externally balanced, while the others are internally balanced..... or do I have that backwards too?
Old 06-21-2010, 02:48 AM
A.K.A Bob Dodge
some 340s had cast external ballanced cranks, also the 67 and earlier 273 heads had a different angle on the intake side, meaning only the pre 68 273 intake will bolt on, the later intakes will cause a vacuum leak,
Old 06-21-2010, 07:05 AM
so 318 intakes won't correctly fit on the 273's?
Old 06-21-2010, 12:08 PM
A.K.A Bob Dodge
318 intakes will fit fine on the 68,69 blocks, but not eairlier
paratrooper27th
05-11-2023 01:55 PM
Fwmoraes
12-05-2019 04:45 PM
keith811
01-13-2011 10:43 AM
mlithgow
11-26-2008 02:15 AM
1982dodgeram
11-23-2008 02:42 AM
Quick Reply: Engine swap 318 to 360
