Question on spread bore Holley installation
Old 02-25-2011, 09:03 PM
73Dodge400's Avatar
Hi,
I have a Holley 80555 GM Spread bore carb that I need to install on a 1973 Chrysler 383 Spread bore manifold. How should I set the throttle linkage up so that it will work with my 1973 Dodge D200 2wd? The engine is a 400 6.6L. Is there an adapter for this setup?
Thanks,
Dave
Old 02-26-2011, 02:41 AM
I'm sure that rickyr will chime in as he works for Holley and should be able to answer your question.
Old 02-26-2011, 09:44 AM
73Dodge400's Avatar
That would be great. So far I am suspecting that I will need to use a spacer to raise the carb up a bit, and that there is no Chrysler linkage adapter made for spread bore holley carbs, only square bore.
DUSTERforLIFE
09-14-2012 05:46 AM
TwistedWrenches
06-03-2009 06:45 PM
craveman
04-11-2009 04:55 PM
y84media
06-26-2008 08:27 AM
Zach8200
05-06-2008 01:40 PM
Quick Reply: Question on spread bore Holley installation
