replacing a shift shaft seal in a 727 tranny
Old 10-21-2009, 07:47 AM
72D100dodge's Avatar
how do i replace a shift shaft seal in my 727 tranny?
Old 12-05-2009, 04:39 AM
blue 68 gts's Avatar
Pull the pan off, pull the valvebody out. You should see the insides of the trans. Seal should be on the casing right under the valve body
Robert (04-15-2012)
Old 12-06-2009, 11:39 AM
Senior Member
OutlawCuda's Avatar
Smile
Hi welcome to the sight. If you do a search 727 Trans Leak - Selector Shaft Seal? You will find all the info you need. I can also email you a page from the service manual if you need it.
Robert (04-15-2012)
Old 04-15-2012, 04:18 PM
Robert's Avatar
hey outlaw could you e-mail me that service page for the selector seal replacement. i'm not a mech. but i can fallow directions do you think i can do thins myself? just paid to have front seal and pan gasket replaced and still have the same leak @#$% it love my D 200 and want to keep it in good shape really glad i found this sight well thanks for any help you can offer
Robert
Old 04-15-2012, 04:19 PM
Robert's Avatar
Originally Posted by Robert
hey outlaw could you e-mail me that service page for the selector seal replacement. i'm not a mech. but i can fallow directions do you think i can do thins myself? just paid to have front seal and pan gasket replaced and still have the same leak @#$% it love my D 200 and want to keep it in good shape really glad i found this site well thanks for any help you can offer
Robert
Old 04-15-2012, 07:15 PM
IT can be done without dropping the pan but it is a "B" without the correct tool. I would advise buying an extra seal..if you try. Other wise drop the pan and remove the valve body to gain access to the seal. A large C clamp and some sockets helps press the seal into place. I like to used Permatex with the brush, light coat on the trans / seal surface..
Don't forget to lube the seal surface- light coat of silicon grease works or just some trans fluid. It's a bit pricy The later 518 trans uses a black reinforced gasket that will not leak...
There is also a small seal in the shifter levers too, under the washer/ C clip
Robert (04-16-2012)
Shrug
03-26-2013 04:41 PM
furyaboveall
10-02-2010 08:04 AM
furyaboveall
11-22-2009 11:51 AM
72D100dodge
11-04-2009 11:42 AM
Seg1955
01-16-2009 01:10 PM
Quick Reply: replacing a shift shaft seal in a 727 tranny
