2006 2500 5.7 weird code?
I keep getting this code that I can not figure out. Its P0004. Doesnt show up on any list that I have looked at. Any ideas? Check engine light comes on but its running well.
This is what I found.
P0004 - Fuel Volume Regulator Control Circuit High
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Tech notes
The P0004 is an OBDII generic code, but almost none of the vehicle manufactures use it. If you are getting this code, make sure you are using the correct OBDII code scanner for your vehicle's make and model.
P0004 Description
Fuel Volume Regulator Control Circuit High is the generic definition for the P0004; however your vehicle's manufacturer may have a different definition for the P0004 code.
Symptoms
Tech notes
P0004 Description
I did clear the code and this morning came up with this p0420, catalyst efficiency.
I did just replace both manifolds (exhaust) and all 4 O2s a week ago. Cleaned throttle plate and intake. Runs great! Just trying to pinpoint the codes that are coming up. Bad cat or maybe software in the engine controller? Who knows.
parrothead6970
02-17-2011 07:14 AM
