82 ram
Guest
Posts: n/a
82 ram
New here hope to be around for a good while.
I have a 1982 d150 ram with a 318 auto tranny
It currently runs pretty good but the engine stalls when under hard acceleration, if you play with the pedal it will even burn out.
I have another complete engine out of a 85 ram charger that has under 100k miles and was running perfect before i pulled it
I'd like to install this "new" engine on the 82 ram after i do some work to it...
I'd like to get close to 400hp but keep in mind that this will be a daily driver so maybe im going a litle too far.
this is what i have in mind
HEADS
port a polish stock 318 heads (302 castings)
install bigger valves
Cam
Install a new Comp Xtreme Energy 268
dont really know what intake and carb just yet
Please tell me what you guys think!
I got all the info at this website
http://www.hotrod.com/howto/113_0304...ild/index.html
HEADS
Cam
Look around for a set of "j" heads or "x" heads. they will flow much better than the ones that you have now. As for an intake and carb, do not go with Weiand. I installed a Weiand intake on my 78d200 with a 318 and it never sealed properly. Spend a little extra and go with Edlebrock performer intake and carb. You might be able to use the stock kickdown linkage as well. If not hten you will need to buy some cables.
400 horse from a "teener"
Four hundred horse from a 318 might be kinda hard. I think I would try the magnum heads from a place called Enginequest. Mopar Action just did a comparison of a bunch of available smallblock heads and the enginequest heads faired pretty well, considering the price they are sold at. They beat the stock magnums by a mile and even flowed better than the magnum r/t heads. Here is their website- www.aaeq.net . Along with the magnum heads, I would go with some Keith Black hypereutectic pistons [maybe the 167's], an Edelbrock Performer Airgap manifold, some decent 1-5/8 hedders, a Holley 650 vacuum secondary carburetor with a 1 inch spacer and an MSD ignition system. The Comp Cams Extreme Energy 268 is a good choice for the cam although you might get by with the next size smaller for the smaller cubes of the 318. Well, good luck with your project and hope you have truckloads of fun with it!!!
