Optimal Fuel Consumption
Old 05-02-2009, 01:12 PM
Well with more air means more gas. A programmer would help you out. A cold air intake and exhaust will help out with power for hauling and towing, you might get some better gas milage.
Best piece of advice I can give is to take it easy with it, don't get on it, do the speed limits. I drive 55 on the highway to work in my Dakota (01, V6, 5 spd, 2WD)and get 23-25 MPG.
Old 05-03-2009, 06:42 AM
cold air intakes and exhaust will increase your mpg's, but not too drastically
Old 05-03-2009, 07:13 PM
The programmer will really only help you with your motor since you have a manual, so you won't be able to get the full effects of it. I'd stay away from the programmer then.
What about an undredrive pulley kit? Short throw shifter? I know that a HD/performance clutch will help to get more power to to the tranny and to your tires so in a way, you won't be wasting fuel.
NYCuda
04-28-2015 06:42 AM
AARinOntario
09-28-2013 08:14 PM
CitronPresse
03-15-2011 10:33 AM
Quick Reply: Optimal Fuel Consumption
