Go Back   Mopar Forums > RACING / RECREATIONAL > Street n Strip
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-04-2008, 04:23 PM   #1 (permalink)
jeep360
Junior Member
Adding some pep to a 360?
I am am about to rebuild the motor in my 98 jeep and need some suggestions on what to do to add some serious power? I want to stay away from nitrous but i want something that will hold its own at the strip. Everyone tells me that head work does wonders for the 360, any suggestions?
jeep360 is offline   Reply With Quote
Old 08-05-2008, 03:11 AM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Very simple ... a 4" cast crank and a set of Eddy heads !
Doc is offline   Reply With Quote
Old 08-15-2008, 05:39 PM   #3 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
when i worked at a jeep dealership a few years back, a guy came in with a 98 GC limited. he bored and stroked it and let me tell you, that thing was nasty. you want serious power, look into that... and a good tranny to back it up.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
Old 08-15-2008, 09:49 PM   #4 (permalink)
jeep360
Junior Member
yeah, i have heard the bored and stroked idea several times but i am in college and on a bit of a budget so i am looking for a somewhat cheaper option.
Old 08-15-2008, 10:04 PM   #5 (permalink)
Quote:
there are manifolds, injectors, air intakes, and exhausts out there that you can choose from. it all depends on how much HP and torque your gunning for. however you build you motor, make sure that your tranny, t-case, axles and tires can handlt it. its not just one part of the drivetrain that you have to worry about. you have to make sure that its all going to work together. look into posi units front and rear. that will help you out.
__________________
Tim and Heather
Old 08-15-2008, 10:42 PM   #6 (permalink)
Doc
MasterDebater
Doc's Avatar
Why don't you consider a plate Nitrous system?
Old 08-16-2008, 05:30 AM   #7 (permalink)
supercharger?
__________________
Tim and Heather
Old 09-01-2008, 04:13 PM   #8 (permalink)
helomechs
Junior Member
got stroker kit form mancini, internal balance diamond piston etc, edelbrock heads flowed like crap out of box very inconsistent. but still better than stock. port work made them nicer, crane retrofit roller cam, 11.3:1 comp super victor intake speed demon 850dp. made 385bhp approx 407tq at wheels on dyno. then found intake milling wrong. it was sucking oil out of the valley with air on all 8 cyclinders. currently fixing that. so expecting it to rock pretty good when its all buttoned up. runs great on pump gas, hp get up there about 3000rpm and stays really straight across all the way to 5250 then falls. nice looking power band. only get about 5mpg though
if you do go with edelbrock heads. get them bare and buy some quality valves like manley race flo or severe duty. you'll be glad you did. wish i had to begin with. i have to now.
helomechs is offline   Reply With Quote
Old 09-01-2008, 08:31 PM   #9 (permalink)
Doc
MasterDebater
Doc's Avatar
Hey helo ... this guy has a "hamburger" budget ... and you suggest a "prime-rib" recipe ?? ...... !!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
timing on 73 - 360 gotdust General Technical Questions 0 07-14-2008 03:20 PM
Adding a digital camera to an old tower ?? Doc Off Topic 5 06-27-2008 12:44 PM
adding '302 heads to a 318 motor ??? crioten General Technical Questions 3 05-09-2008 01:24 AM
old school 360 to new style 360 choelzer General Discussion 2 02-29-2008 04:00 AM
360 Green Dakota General Technical Questions 8 11-11-2007 03:04 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
