bolt on performance suspension
Does anybody know of a company that sells a bolt on front or rear performance suspension such as a coil over front suspension with tubular A-arms.? Maybe ones from another vehicle that will work? The rear suspension has been difficult to find anything for besides leaf springs and lowering shackles. I haven't been able to find any kind of traction bar or ladder bar to bolt on. Even the traction bars that are for the rear axle with leaf springs on top don't fit. Any help would be appreciated. thank you
Calvert racing can set up your rear suspension with a slit monoleaf Caltrack bars adjustable shocks the works.🙂
bolt on ?
Thank you for responding. Do you know if that's bolt on or grind and weld? I'm trying to loose some weight off the truck without fiberglass which they don't make much anyway. Thank you again.
It's a direct replacement for your leaf springs and it does save weight plus works in 8 second rides.
https://www.calvertracing.com/index.php |
I checked Calvert racing out. They have an order from specifically for trucks that asks a bunch of questions about the rear suspension so the can make the right one but I didnt see any prices which is no big deal when your doing this stuff anyway. I'm going to give them a call. Thanks again for the info.
You bet, have fun.
