bolt on performance suspension
Old 03-17-2019, 03:25 PM
truckracinpartsguy's Avatar
Does anybody know of a company that sells a bolt on front or rear performance suspension such as a coil over front suspension with tubular A-arms.? Maybe ones from another vehicle that will work? The rear suspension has been difficult to find anything for besides leaf springs and lowering shackles. I haven't been able to find any kind of traction bar or ladder bar to bolt on. Even the traction bars that are for the rear axle with leaf springs on top don't fit. Any help would be appreciated. thank you
Old 03-17-2019, 05:50 PM
Calvert racing can set up your rear suspension with a slit monoleaf Caltrack bars adjustable shocks the works.🙂
Old 03-17-2019, 06:07 PM
bolt on ?
Thank you for responding. Do you know if that's bolt on or grind and weld? I'm trying to loose some weight off the truck without fiberglass which they don't make much anyway. Thank you again.
Old 03-17-2019, 06:27 PM
It's a direct replacement for your leaf springs and it does save weight plus works in 8 second rides.
https://www.calvertracing.com/index.php
Old 03-18-2019, 05:33 AM
I checked Calvert racing out. They have an order from specifically for trucks that asks a bunch of questions about the rear suspension so the can make the right one but I didnt see any prices which is no big deal when your doing this stuff anyway. I'm going to give them a call. Thanks again for the info.
Old 03-18-2019, 06:29 AM
You bet, have fun.
Pistol pete
11-13-2015 10:22 AM
Pistol pete
11-12-2015 07:25 PM
Allens366
11-09-2014 07:33 PM
393stroker
08-16-2013 01:52 PM
dartmancan
02-26-2007 09:22 AM
Quick Reply: bolt on performance suspension
