Jim's36 Overheating problem
on
Hello Everyone I'm new hear and need help.Just got a new 36 dodge coupe with a 340 small block.I changed the heads to Edelbrock rpm and the intake to the Edelbrock rpm air gap.Put in a new aluminum radiator new water pump new thermostat.Overheats now after startup.Engine goes up to 250 and the hoses in and out of the radiator are cool.Can't figure it out.Also I thought maybe I was having a problem with maybe air in the cooling system so I purchased the air evacuation system from Summit and used it to put in my antifreeze and it worked well but the problem is still there.
on
