New member in SW Florida
Old 09-22-2011, 09:24 PM
Bill's Avatar
Hello, I own a 1986 Dodge Ram D150 with a slant 6.
Because of military injuries my truck has been sitting for the past 3 years.
I am finally able to drive it again but I would like to fix this up a little before putting it back on the road.
I am not certain what color to paint the truck currently it is white with a maroon dash and white metal inside the cab.
I did find a set of rims and tires that I plan to order from tirerack.com.
I will be installing 16 inch rims in place of the 15 inch ones that are currently rusting away.
For some reason I had a very hard time finding rims to fit this truck.
I am looking for suggestions on what I should do to the truck, so if you have any suggestions please let me know.
Thanks Bill
Old 09-23-2011, 02:46 AM
Welcome and thank you for serving!
If you can, post up a picture of the truck as it will help us to see it.
Old 09-23-2011, 05:44 AM
DartcustomcrusieR's Avatar
hell yeah! a /6! welcome to the forums!
Old 09-23-2011, 07:21 PM
Bill's Avatar
I've added some photos of my truck.
Bill
Old 09-23-2011, 08:07 PM
chlngr1970's Avatar
Leaning Tower of Power! All RIGHT!
Good luck on the build, and thanks for your service
j
Old 09-23-2011, 08:09 PM
chlngr1970's Avatar
Suggestions are like...
you get the idea
As for what I would do with it...
Depending on your states emission control laws, I'd either go 440/727, or 5.9 magnum/A518 with full blown Fuel Injection. Either way, you will have PLEANTY of power.
What do YOU want out of the truck is the MOST important thing tho...
j
Old 09-25-2011, 06:12 AM
Welcome to the forum... As already said, what do you want to do with the truck when you are done... Road, race or what ever.... Anyway, welcome to the forum.... Be sure to check out the Mopar of the Month contest.. See the sticky for the simple rules and then you can help choose the monthly winners....
Old 09-25-2011, 06:45 AM
Welcome from Canada.
Regarding any improvements a pencil and paper with your goals is the best place to start. If your looking at towing or more power don't overlook the rear axle. It most likely has an 8 1/4" (10 bolt cover) which are weak, if 9 1/4" (12 bolt cover,like a stop sign) you can feel better. Gear ratio would be good to find out when you start planning too.
Old 09-25-2011, 06:49 AM
rickyr's Avatar
Old 09-25-2011, 08:24 AM
as said before, what are your plans/budget for the car?
Old 09-26-2011, 01:06 PM
Bill's Avatar
reply to questions
My goals for the truck is to keep it street legal.
With all the injuries I have from the military I am not able to use a clutch or to race (Wish I could I used to love the track).
Once I get the new tires on I plan to have the engine checked out.
I am really hopping that it is still good on the pressure
This engine has about 40,000 - 45,000 miles since the last owner had it rebuilt.
I would like to work on improving the suspension and possibly replacing the rear-end.
Being disabled the money is tight but I do have about a grand to start the work then I will have to do a little each month after that is spent.
And since I am not able to do most of the work myself this is going to cost quite a lot.
I was thinking of a color to paint the truck, the inside is maroon so I was thinking about a blackish red for both the inside and out.
The new wheels I purchased for the truck are black and chrome.
I found these at www.tirerack.com they are some of the cheaper wheels but they look good and they are a lot better then the rusted white wheels that is on the truck now.
I will be getting rid of the topper and replace that with a hard cover over the bed area.
I will also have the bench seat redone along with new carpet.
Bill
Doubleclutch
11-03-2014 03:23 AM
4004speedrunner
05-29-2012 04:40 PM
flmopars
12-17-2009 05:42 PM
flmopars
06-20-2009 02:27 PM
monsturband
07-21-2008 06:25 PM
Quick Reply: New member in SW Florida
