Old gearhead, but new to MOPARs
Old 11-03-2009, 05:53 PM
  #31
pjmopar's Avatar
Hi Bryan very nice car ,love the old mopars.Im not totally sure but i think they make a special motor mount ,so you dont have to swap the k frame for a v8 swap
Old 11-08-2009, 03:53 PM
  #32
GrabberOrange69's Avatar
Originally Posted by Polaradude
Did you figure anything out with regards to the rear end ? If you can locate the casting numbers on the rear. If it is a "741" ( the small pinion 1 3/8" ) 8 3/4 the casting will have a large X cast in the left side.
If the rear is the "742" this is the large pinion rear ( 1 3/4" ) it may have a large 2 cast on the left side.
If the rear is the "489" this is the tapered pinion ( 1 7/8" ) it will have a large 9 stamped in it. Through 1965 the ratio was stamped in the id boss of the rear end followed by an S for sure grip. After 65 the ratio was stamped in a tag that was located under the carrier mounting nuts. Sometimes there was a Sure Grip lube tag applied or as crazy as this is the filler nut/plug was painted orange.
Let us know what ya find man.
"If it is a "741" ( the small pinion 1 3/8" ) 8 3/4 the casting will have a large X cast in the left side"
Yep -it's got the big "X". Obviously the pinions aren't interchangable between the above, but what about the posi?
Also, when I pulled a wheel, it has an axle flange just like a 9" Ford would have.
Old 11-09-2009, 12:21 PM
  #33
Polaradude's Avatar
The two sure grips can be interchanged between the carriers if the matching differential axle bearings are retained. The outside cup diameter is the same between 741/742 and with the 489 the inner cone differs. Prior to 64 there are thrust block differences which F&ck things up.
Clear as mud ? Ask away man, I got loads of paper on this stuff.
I also have axle data too Bryan. Let me know man.
Mr.4spd
10-21-2014 05:19 AM
dgp_naples
07-18-2013 09:24 AM
kaferman62
04-23-2009 01:29 PM
anmracing
06-30-2008 12:53 PM
dustininwy
11-01-2007 07:51 PM
Quick Reply: Old gearhead, but new to MOPARs
