Head Gasket Failure 3.0
Old 07-05-2015, 07:48 PM
armeniansdoitbetter's Avatar
Recently had the head gaskets on 93 Lebaron replaced. the repair failed after less than a week. The shop ended up reusing the head bolts and I am pretty sure they did not torque them down as specified as they informed me that I would need to come back to do a follow up and re-torque them.... The mechanic is blaming my fel pro gasket set.....
Is this a TTY engine and why would head bolt tightening be necessary if cold 80 in 3 steps is recommended?
Old 07-06-2015, 05:14 AM
Were the heads surfaced?
Old 07-06-2015, 05:35 AM
No they were not.
Old 07-06-2015, 10:48 AM
Sounds like they should have been, ether that or you have a cracked head.
Old 07-07-2015, 04:31 AM
I did wonder that. I have a hunch that it wasn't torqued correctly.
Old 07-07-2015, 05:10 AM
You cant seal a warped head with any gasket, at least not very long.
Old 07-07-2015, 11:35 AM
Fel Pro makes a good gasket set.. Something else is wrong. A proper mechanic should have at least checked the heads with a straight edge, had them pressure tested and replaced the bolts instead of cutting corners.
If you have a torque wrench ?? Check the torque settings !
Boompy
11-26-2017 09:50 AM
Dave E
03-12-2014 05:30 PM
fivepoint
08-20-2012 11:19 PM
Greaser
08-03-2011 01:06 PM
MarkyMark12345
04-16-2009 06:46 PM
Quick Reply: Head Gasket Failure 3.0
