NHRA AAA Finals Pomona
Old 11-11-2011, 04:33 AM
Thu, 10 Nov 2011, 15:42 PM
Pro Stock Qualifying Notes, Session #1
By David Gerard
POMONA, Calif. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 47th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Mark Wolfe Runs 6.601/210.21, Now #1
Right Lane: Grace Howell Runs 6.615/208.97, Now #2
12:14 p.m. . Weather conditions: air temperature 74 degrees, relative humidity 21 percent, barometer 29.03 inches, adjusted altitude 2,322 feet, track temperature 84 degrees.
We have a full overcast now and the just completed ProStock Bike session was fast and quick.
Mustangs a pair to the line. It's a new career best for Wolfe, but I don't think it will make the cut.
Left Lane: Gordie Rivera Runs 6.766/206.07, Now #4
Right Lane: Buddy Perkinson Runs 6.628/208.75, Now #3
Rivera's GXP is a little slow off the line and is well off his best. No big numbers for Perkinson either.
Left Lane: Steve Kent Runs 6.609/209.14, Now #3
Right Lane: Warren Johnson Runs 6.595/210.44, Now #1
Johnson chatters the tires off the line and he still cards our first sub-sixty time.
Nice pass for Kent too.
Left Lane: V. Gaines Runs 6.750/178.83, Now #7
Right Lane: Larry Morgan Runs 6.554/210.97, Now #1
Gaines' car steps out towards the wall at the green and it costs him
Great pass for Morgan to take over the new top spot.
Left Lane: Kurt Johnson Runs 6.560/211.06, Now #2
Right Lane: Ronnie Humphrey Runs 6.570/211.13, Now #3
Both cars run well and slid into the top of the ladder near to top.
Left Lane: Ron Krisher Runs 9.742/89.92, Now #12
Right Lane: Shane Gray Runs 6.572/211.03, Now #4
Krisher's GXP goes wacky off the line and drives hard towards the center line. He horses it back and clicks it early.
Clean and straight for Gray into the new #4 spot.
Left Lane: Greg Stanfield Runs 6.578/209.75, Now #6
Right Lane: Rodger Brogdon Runs 6.563/210.57, Now #3
Happy 51th Birthday Roger Brogdon!
Ron Krisher is on the bump spot at 9.742.
Two more clean passes into the top half of the field. Stanfield's numbers were better on the bottom of the track. Brogdon on the top.
Left Lane: Erica Enders Runs 6.601/210.87, Now #8
Right Lane: Allen Johnson Runs 6.620/197.77, Now #12
V. Gaines is on the bump spot at 6.750.
Johnson was strong down low, but just gets in on the bump. Enders has the top end charge, running the second fastest pass of the session.
Left Lane: Vincent Nobile Runs 6.561/211.20, Now #4
Right Lane: Greg Anderson Runs 6.537/211.46, Now #1
Allen Johnson is on the bump spot at 6.620.
Nobile's car moves around a little off the line and he moves into the number four spot. Classis Summit pass and Anderson has low ET and top speed.
Vincent Nobile's incremental times: 60ft-0.983 sec., 330ft-2.753, 660ft-4.226/167.34 mph, 1,000ft-5.494.
Greg Anderson's incremental times: 60ft-0.977 sec., 330ft-2.743, 660ft-4.209/168.28 mph, 1,000ft-5.472.
Left Lane: Mike Edwards Runs 6.520/210.93, Now #1
Right Lane: Jason Line Runs 6.538/211.20, Now #3
Last pair. Steve Kent is on the bump spot at 6.609.
Edwards starts with the best 60 foot time and thunders on down the track and into the final top spot. Line is off the line first, but can't quite match the pace and has to settle for #3 today.
12:36 p.m. Erica Enders is on the bump spot at 6.601.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old 11-11-2011, 01:35 PM
Round 2 Qualifying
Fri, 11 Nov 2011, 16:18 PM
Pro Stock Qualifying Notes, Session #2
By David Gerard
POMONA, Calif. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 47th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Buddy Perkinson Runs 6.713/206.70, Now #17; Best prior run: 6.628/208.75, Was #17
Right Lane: Ron Krisher Runs 18.866/45.35, Now #20; Best prior run: 9.742/89.92, Was #20
12:42 p.m. Weather conditions: air temperature 73 degrees, relative humidity 23 percent, barometer 28.75 inches, adjusted altitude 2,654 feet, track temperature 87 degrees.
Lots of high broken clouds now. Erica Enders is on the bump spot at 6.601.
Krisher fires and falls back. Perkinson gets to the finish line under power, but slows.
Left Lane: Allen Johnson Runs 6.575/210.60, Now #10; Best prior run: 6.620/197.77, Was #16
Right Lane: Gordie Rivera Runs 6.755/205.76, Now #19; Best prior run: 6.766/206.07, Was #19
Rivera's GXP makes a little move towards the center line at the green and he drives it back.
Johnson gets back in the field for now, but not as far up the ladder as he needs to be.
Allen Johnson's incremental times: 60ft-0.984 sec., 330ft-2.756, 660ft-4.233/166.64 mph, 1,000ft-5.504.
Left Lane: Grace Howell Runs 6.632/208.55, Now #17; Best prior run: 6.615/208.97, Was #16
Right Lane: V. Gaines Runs 6.595/209.88, Now #13; Best prior run: 6.750/178.83, Was #18
A little darting around for both cars. Gaines picks up a bunch, but just not enough.
V. Gaines' incremental times: 60ft-0.989 sec., 330ft-2.769, 660ft-4.248/166.79 mph, 1,000ft-5.522.
Left Lane: Warren Johnson Runs 6.636/209.01, Now #12; Best prior run: 6.595/210.44, Was #12
Right Lane: Steve Kent Runs 6.610/209.85, Now #16; Best prior run: 6.609/209.14, Was #16
No joy here, as both cars slow a little.
Warren Johnson's incremental times: 60ft-0.990 sec., 330ft-2.786, 660ft-4.276/165.42 mph, 1,000ft-5.557.
Steve Kent's incremental times: 60ft-0.989 sec., 330ft-2.773, 660ft-4.257/166.31 mph, 1,000ft-5.535.
Left Lane: Shane Gray Runs 6.574/210.70, Now #9; Best prior run: 6.572/211.03, Was #9
Right Lane: Mark Wolfe Runs 6.812/207.59, Now #15; Best prior run: 6.601/210.21, Was #15
Gray makes a clean pass to run close to his prior best.
Wolfe spins the tires off the line and slows.
Mark Wolfe's incremental times: 60ft-1.022 sec., 330ft-2.915, 660ft-4.432/163.39 mph, 1,000ft-5.726.
Left Lane: Ronnie Humphrey Runs 6.566/210.44, Now #8; Best prior run: 6.570/211.13, Was #8
Right Lane: Erica Enders Runs 6.596/210.24, Now #14; Best prior run: 6.601/210.87, Was #14
Enders needs a strong pass to bump back in. Warren Johnson is on the bump spot at 6.595.
Humphrey's car does a quick dart around at the shift and he still picks up a little ET to stay #10.
Enders has a clean start and a little improvement, but will stay #14.
Ronnie Humphrey's incremental times: 60ft-0.982 sec., 330ft-2.754, 660ft-4.228/167.22 mph, 1,000ft-5.496.
Erica Enders' incremental times: 60ft-0.990 sec., 330ft-2.772, 660ft-4.251/167.01 mph, 1,000ft-5.524.
Left Lane: Rodger Brogdon Runs 6.606/209.85, Now #7; Best prior run: 6.563/210.57, Was #7
Right Lane: Greg Stanfield Runs 14.841/52.41, Now #11; Best prior run: 6.578/209.75, Was #11
The rest of the cars in the session are already in the field.
Brogdon moves a bunch towards the centerline and drives it back.
Stanfield is eleven on 11/11/11. Lots of shake and spin off the line.
Rodger Brogdon's incremental times: 60ft-0.990 sec., 330ft-2.779, 660ft-4.259/166.85 mph, 1,000ft-5.532.
Greg Stanfield's incremental times: 60ft-1.000 sec., 330ft-3.771, 660ft-7.263/063.61 mph, 1,000ft-10.987.
Left Lane: Larry Morgan Runs 6.575/210.01, Now #4; Best prior run: 6.554/210.97, Was #4
Right Lane: Vincent Nobile Runs 6.612/209.95, Now #6; Best prior run: 6.561/211.20, Was #6
No improvements here.
Larry Morgan's incremental times: 60ft-0.985 sec., 330ft-2.752, 660ft-4.227/166.60 mph, 1,000ft-5.501.
Vincent Nobile's incremental times: 60ft-0.995 sec., 330ft-2.776, 660ft-4.261/166.13 mph, 1,000ft-5.538.
Left Lane: Jason Line Runs 6.553/210.77, Now #3; Best prior run: 6.538/211.20, Was #3
Right Lane: Kurt Johnson Runs 6.589/209.65, Now #5; Best prior run: 6.560/211.06, Was #5
Best of the round for Line, but no improvement. Johnson makes another good pass and stays #5.
Jason Line's incremental times: 60ft-0.976 sec., 330ft-2.746, 660ft-4.217/167.49 mph, 1,000ft-5.484.
Kurt Johnson's incremental times: 60ft-0.976 sec., 330ft-2.755, 660ft-4.237/166.27 mph, 1,000ft-5.513.
Left Lane: Greg Anderson Runs 6.543/211.66, Now #2; Best prior run: 6.537/211.46, Was #2
Right Lane: Mike Edwards Runs 6.560/211.00, Now #1; Best prior run: 6.520/210.93, Was #1
Last pair and both cars make good passes.
Anderson is quickest and fastest of the session, but will stay #2. Nice clean pass for Edwards too.
Greg Anderson's incremental times: 60ft-0.978 sec., 330ft-2.742, 660ft-4.211/167.61 mph, 1,000ft-5.476.
Mike Edwards' incremental times: 60ft-0.985 sec., 330ft-2.755, 660ft-4.226/167.63 mph, 1,000ft-5.493.
1:10 p.m. Warren Johnson is on the bump spot at 6.595.
Old 11-13-2011, 03:36 AM
Round 3 Qualifying
Sat, 12 Nov 2011, 14:57 PM
Pro Stock Qualifying Notes, Session #3
By David Gerard
POMONA, Calif. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 47th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Ron Krisher Runs 6.587/210.44, Now #12; No Prior Run
Right Lane: Buddy Perkinson Runs 6.598/209.17, Now #14; No Prior Run
11:29 a.m. Weather conditions: air temperature 62 degrees, relative humidity 52 percent, barometer 28.74 inches, adjusted altitude 2,061 feet, track temperature 71 degrees.
No bump for the sixteen car ladder.
Krisher gets a much better run, but this may not last.
Perkinson runs his best pass of the weekend to slide into the #14 spot.
Ron Krisher's incremental times: 60ft-0.991 sec., 330ft-2.766, 660ft-4.245/166.25 mph, 1,000ft-5.517.
Buddy Perkinson's incremental times: 60ft-0.991 sec., 330ft-2.767, 660ft-4.246/166.66 mph, 1,000ft-5.522.
Left Lane: Greg Stanfield Runs 6.602/209.88, Now #11; Best prior run: 6.578/209.75, Was #11
Right Lane: Warren Johnson Runs 19.015/50.46, Now #13; Best prior run: 6.595/210.44, Was #13
Johnson's car stumbles at the green and coasts on down.
Stanfield slows to stay #11.
Greg Stanfield's incremental times: 60ft-0.995 sec., 330ft-2.774, 660ft-4.253/166.74 mph, 1,000ft-5.527.
Left Lane: Mark Wolfe Runs 8.893/106.43, Now #16; No Prior Run
Right Lane: Grace Howell Runs 6.609/209.07, Now #15; No Prior Run
Wolfe's car shutters off the line and slows
Howell matches her careen best and moves into the bottom half of the field in #15.
Grace Howell's incremental times: 60ft-0.984 sec., 330ft-2.767, 660ft-4.251/166.17 mph, 1,000ft-5.531.
Left Lane: Gordie Rivera Runs 6.716/205.13, Now #16; No Prior Run
Right Lane: Rodger Brogdon Runs 6.552/211.06, Now #4; Best prior run: 6.563/210.57, Was #7
Rivera makes his best run of the weekend and a season best to take over the bump spot.
Great pass for Brogdon into the top four on the ladder.
Gordie Rivera's incremental times: 60ft-0.985 sec., 330ft-2.797, 660ft-4.313/162.45 mph, 1,000ft-5.618.
Rodger Brogdon's incremental times: 60ft-0.977 sec., 330ft-2.746, 660ft-4.217/167.74 mph, 1,000ft-5.485.
Left Lane: Vincent Nobile Runs 6.605/210.11, Now #7; Best prior run: 6.561/211.20, Was #7
Right Lane: Larry Morgan Runs 6.595/210.21, Now #5; Best prior run: 6.554/210.97, Was #5
Both cars are already in the field.
Morgan's Mustang darts around off the line and doesn't improve.
No help for Nobile either.
Vincent Nobile's incremental times: 60ft-0.990 sec., 330ft-2.775, 660ft-4.258/166.19 mph, 1,000ft-5.532.
Larry Morgan's incremental times: 60ft-0.986 sec., 330ft-2.770, 660ft-4.250/166.52 mph, 1,000ft-5.523.
Left Lane: Steve Kent Runs 6.588/210.14, Now #13; No Prior Run
Right Lane: Allen Johnson Runs 6.587/210.80, Now #10; Best prior run: 6.575/210.60, Was #10
Only 0.001 difference in ET's.
Johnson stays #10 and Kent makes a big move up the ladder into the new #13 spot.
Steve Kent's incremental times: 60ft-0.987 sec., 330ft-2.767, 660ft-4.244/166.76 mph, 1,000ft-5.516.
Allen Johnson's incremental times: 60ft-0.995 sec., 330ft-2.769, 660ft-4.246/166.93 mph, 1,000ft-5.517.
Left Lane: Erica Enders Runs 6.578/210.93, Now #11; No Prior Run
Right Lane: Shane Gray Runs 6.571/210.64, Now #9; Best prior run: 6.572/211.03, Was #9
Grace Howell is on the bump spot at 6.609.
Last change for Enders to be able to bump in this session and she does so!
Two clean and straight and true, but not into the top half of the field.
Erica Enders' incremental times: 60ft-0.997 sec., 330ft-2.772, 660ft-4.243/167.45 mph, 1,000ft-5.510.
Shane Gray's incremental times: 60ft-0.980 sec., 330ft-2.755, 660ft-4.230/167.28 mph, 1,000ft-5.501.
Left Lane: V. Gaines Runs 6.609/209.98, Now #17; No Prior Run
Right Lane: Ronnie Humphrey Runs 6.576/210.54, Now #8; Best prior run: 6.566/210.44, Was #8
Buddy Perkinson is on the bump spot at 6.598.
Gaines times from yesterday would of had him on the bump, but he can't improve today to miss the field.
Humphrey's slows just a tad to stay #8.
V. Gaines' incremental times: 60ft-1.008 sec., 330ft-2.787, 660ft-4.265/166.66 mph, 1,000ft-5.537.
Ronnie Humphrey's incremental times: 60ft-0.991 sec., 330ft-2.764, 660ft-4.238/167.18 mph, 1,000ft-5.507.
Left Lane: Kurt Johnson Runs 6.576/210.54, Now #6; Best prior run: 6.560/211.06, Was #6
Right Lane: Jason Line Runs 6.554/211.06, Now #3; Best prior run: 6.538/211.20, Was #3
No improvement for either driver.
Kurt Johnson's incremental times: 60ft-0.977 sec., 330ft-2.753, 660ft-4.232/166.50 mph, 1,000ft-5.504.
Jason Line's incremental times: 60ft-0.980 sec., 330ft-2.750, 660ft-4.221/167.66 mph, 1,000ft-5.487.
Left Lane: Mike Edwards Runs 6.574/210.83, Now #1; Best prior run: 6.520/210.93, Was #1
Right Lane: Greg Anderson Runs 6.556/211.39, Now #2; Best prior run: 6.537/211.46, Was #2
They leave almost together and run identical 0.981 sixty foot times. They run side by side down the track and Anderson gets there first to wrap up the session.
Mike Edwards' incremental times: 60ft-0.981 sec., 330ft-2.761, 660ft-4.237/166.87 mph, 1,000ft-5.506.
Greg Anderson's incremental times: 60ft-0.981 sec., 330ft-2.754, 660ft-4.225/167.59 mph, 1,000ft-5.490.
11:51 a.m. Buddy Perkinson is on the bump spot at 6.598.
Old 11-13-2011, 03:39 AM
Final Qualifying
Sat, 12 Nov 2011, 19:13 PM
Pro Stock Qualifying Notes, Final Session
By David Gerard
POMONA, Calif. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 47th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Grace Howell Runs 17.457/46.24, Now #18; Best prior run: 6.609/209.07, Was #18
Right Lane: Mark Wolfe Runs 6.707/208.88, Now #19; Best prior run: 8.893/106.43, Was #20
3:42 p.m. Weather conditions: air temperature 65 degrees, relative humidity 55 percent, barometer 28.68 inches, adjusted altitude 2,345 feet, track temperature 68 degrees.
The track is really starting to cool off now and we have threatening weather just to the south of us, coming this way. Buddy Perkinson is on the bump spot at 6.598.
No joy here, as Howell has problems right off the line and slows. Wolfe's Mustang drifts towards the center line down track and will not qualify.
Mark Wolfe's incremental times: 60ft-1.014 sec., 330ft-2.858, 660ft-4.345/166.91 mph, 1,000ft-5.627.
Left Lane: Buddy Perkinson Runs 6.600/209.10, Now #16; Best prior run: 6.598/209.17, Was #16
Right Lane: Gordie Rivera Runs 6.724/206.23, Now #20; Best prior run: 6.716/205.13, Was #20
No improvement for either car. Perkinson stays on the bump for now.
Buddy Perkinson's incremental times: 60ft-0.986 sec., 330ft-2.762, 660ft-4.244/166.07 mph, 1,000ft-5.522.
Gordie Rivera's incremental times: 60ft-1.003 sec., 330ft-2.822, 660ft-4.331/163.51 mph, 1,000ft-5.630.
Left Lane: Warren Johnson Runs 6.625/209.30, Now #15; Best prior run: 6.595/210.44, Was #15
Right Lane: V. Gaines Runs 6.616/209.49, Now #17; Best prior run: 6.609/209.98, Was #17
Last chance for Gaines! Nope... Both cars runs slower than their prior best. Johnson is still in the #15 spot.
Warren Johnson's incremental times: 60ft-0.987 sec., 330ft-2.776, 660ft-4.265/165.42 mph, 1,000ft-5.546.
V. Gaines' incremental times: 60ft-0.985 sec., 330ft-2.774, 660ft-4.260/165.74 mph, 1,000ft-5.539.
Left Lane: Allen Johnson Runs 6.568/211.10, Now #9; Best prior run: 6.575/210.60, Was #10
Right Lane: Steve Kent Runs 15.541/54.67, Now #14; Best prior run: 6.588/210.14, Was #14
Kent's GXP makes a hard move towards the center line at the green and he lifts.
AJ makes a better run this time and just misses the top half of the field to move up one spot to #9.
Allen Johnson's incremental times: 60ft-0.982 sec., 330ft-2.755, 660ft-4.229/167.07 mph, 1,000ft-5.498.
Steve Kent's incremental times: 60ft-0.985 sec., 330ft-3.936, 660ft-7.668/059.46 mph, 1,000ft-11.651.
Left Lane: Shane Gray Runs 6.585/210.05, Now #10; Best prior run: 6.571/210.64, Was #10
Right Lane: Ron Krisher Runs 6.608/206.64, Now #13; Best prior run: 6.587/210.44, Was #13
Gray's right door falls off just as they are ready to move up to do the burnout. They frantically work to fix it and he has to do a very short burnout.
No joy for either team, as they can't improve.
Shane Gray's incremental times: 60ft-0.980 sec., 330ft-2.757, 660ft-4.237/166.64 mph, 1,000ft-5.512.
Ron Krisher's incremental times: 60ft-0.985 sec., 330ft-2.773, 660ft-4.256/166.42 mph, 1,000ft-5.531.
Left Lane: Ronnie Humphrey Runs 6.555/210.77, Now #6; Best prior run: 6.566/210.44, Was #8
Right Lane: Greg Stanfield Runs 6.619/209.07, Now #12; Best prior run: 6.578/209.75, Was #12
Humphrey finds some tune up and move two spots up the ladder to #6. Nice looking pass.
Stanfield will stay #12.
Ronnie Humphrey's incremental times: 60ft-0.976 sec., 330ft-2.742, 660ft-4.215/166.95 mph, 1,000ft-5.485.
Greg Stanfield's incremental times: 60ft-0.995 sec., 330ft-2.780, 660ft-4.263/166.25 mph, 1,000ft-5.541.
Left Lane: Larry Morgan Runs 6.581/210.34, Now #5; Best prior run: 6.554/210.97, Was #5
Right Lane: Erica Enders Runs 26.675/32.04, Now #11; Best prior run: 6.578/210.93, Was #11
Enders car slowly leaves the starting line and slowly coasts down the track. Morgan doesn't improve.
Larry Morgan's incremental times: 60ft-0.983 sec., 330ft-2.756, 660ft-4.235/166.60 mph, 1,000ft-5.508.
Left Lane: Rodger Brogdon Runs 6.590/210.34, Now #4; Best prior run: 6.552/211.06, Was #4
Right Lane: Vincent Nobile Runs 6.634/209.43, Now #8; Best prior run: 6.561/211.20, Was #8
It's tough out there! Neither of these hitters can improve.
Rodger Brogdon's incremental times: 60ft-0.993 sec., 330ft-2.768, 660ft-4.245/166.85 mph, 1,000ft-5.518.
Vincent Nobile's incremental times: 60ft-0.995 sec., 330ft-2.786, 660ft-4.276/165.62 mph, 1,000ft-5.556.
Left Lane: Jason Line Runs 6.560/210.60, Now #3; Best prior run: 6.538/211.20, Was #3
Right Lane: Kurt Johnson Runs 6.600/209.92, Now #7; Best prior run: 6.560/211.06, Was #7
When these two can't improve, it's a tough ol' track out there.
Jason Line's incremental times: 60ft-0.980 sec., 330ft-2.748, 660ft-4.221/167.07 mph, 1,000ft-5.490.
Kurt Johnson's incremental times: 60ft-0.976 sec., 330ft-2.761, 660ft-4.246/165.99 mph, 1,000ft-5.524.
Left Lane: Greg Anderson Runs 6.580/210.90, Now #2; Best prior run: 6.537/211.46, Was #2
Right Lane: Mike Edwards Runs 6.581/210.47, Now #1; Best prior run: 6.520/210.93, Was #1
...and that's a wrap on Pro Stock qualifying for 2012.
Anderson gets away first, but Edwards has better incrementals down low. They run together down the track and finish up just 0.001 different from each other in the lights. They both keep their current positions going into tomorrow's first round of eliminations.
Greg Anderson's incremental times: 60ft-0.984 sec., 330ft-2.759, 660ft-4.237/166.46 mph, 1,000ft-5.509.
Mike Edwards' incremental times: 60ft-0.976 sec., 330ft-2.757, 660ft-4.236/166.74 mph, 1,000ft-5.509.
4:05 p.m. Buddy Perkinson is on the bump spot at 6.598.
Old 11-14-2011, 12:48 PM
Summary of Eliminations
Sun, 13 Nov 2011, 22:10 PM
Summary of Eliminations in Pro Stock
POMONA, Calif. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 47th annual Automobile Club of Southern California NHRA Finals:
Round 1:
Allen Johnson, Greeneville TN, '11 Avenger, Right lane, (0.040) 12.493 71.35 def. Vincent Nobile, Melville NY, '11 Avenger, (-0.002foul) 6.619 202.79
Kurt Johnson, Lawrenceville GA, '09 GXP, Left lane, (0.005) 6.611 209.69 def. Shane Gray, Artesia NM, '09 GXP, (-0.011 foul) 7.480128.86
Greg Stanfield, Bossier City LA, '09 GXP, Right lane, (0.022) 6.595 209.52 def. Larry Morgan, Newark OH, '11 Mustang, (0.075) 6.587210.34
Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.048) 6.572 210.31 def. Ron Krisher, Warren OH, '09 GXP, (0.076) 7.203 140.55
Jason Line, Troutman NC, '09 GXP, Left lane, (0.088) 6.569 210.83 def. Steve Kent, Lottie LA, '09 GXP, (0.110) 6.612 209.62
Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.058) 6.546 210.83 def. Buddy Perkinson, Hopewell VA, '11 Mustang, (-0.003 foul)6.619 208.75
Greg Anderson, Charlotte NC, '09 GXP, Left lane, (0.026) 6.565 211.06 def. Warren Johnson, Buford GA, '09 GXP, (0.087) 6.955 158.84
Ronnie Humphrey, Jacksonville NC, '09 GXP, Left lane, (0.035) 6.556 210.34 def. Erica Enders, Houston TX, '10 Cobalt, (0.028) 6.572210.64
Round 2:
G Stanfield, Right lane, (0.028) 6.605 209.39 def. R Brogdon, (0.050) 6.587 209.82
K Johnson, Right lane, (0.005) 6.595 209.39 def. G Anderson, (0.057) 6.581 210.47
J Line, Right lane, (0.032) 6.552 210.57 def. R Humphrey, (0.043) 6.580 209.65
A Johnson, Right lane, (0.016) 6.603 210.57 def. M Edwards, (-0.006 foul) 6.634 189.20
Round 3:
G Stanfield, Right lane, (0.029) 6.609 209.23 def. A Johnson, (0.035) 6.737 177.46
K Johnson, Left lane, (0.012) 6.606 208.91 def. J Line, (0.034) 7.485 135.91
Round 4:
G Stanfield, Right lane, (0.009) 6.597 209.59 def. K Johnson, (0.016) 19.886 44.02
Low ET: Mike Edwards 6.520 seconds
Top Speed: Greg Anderson 211.66 MPH
Old 11-14-2011, 01:06 PM
Round 1:
Round 2:
Round 3:
Round 4:
Mack, this guy is from where I live...
MReeves
Stock Eliminator
11-14-2011 01:33 PM
MReeves
Super Stock
11-14-2011 01:30 PM
MReeves
Funny Car
11-13-2011 03:48 AM
MReeves
Super Gas
11-13-2011 03:41 AM
MReeves
Pro-Stock
11-15-2010 12:19 PM
Quick Reply: NHRA AAA Finals Pomona
