NHRA Arizona Nationals Phoenix
Old 10-14-2011, 04:26 PM
Fri, 14 Oct 2011, 05:44 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
CHANDLER, Ariz. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 27th annual NHRA Arizona Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Grace Howell Runs 23.253/26.24, Now #2
Right Lane: Gordie Rivera Runs 6.904/201.94, Now #1
Weather conditions: air temperature 89 degrees, relative humidity 24 percent, barometer 28.56 inches, adjusted altitude 3,805 feet, track temperature 129 degrees.
Howell with a lot of tire shake right off the starting line and pushed in the clutch. Rivera was straight down the groove...
Left Lane: Steve Kent Runs 17.660/44.85, Now #3
Right Lane: Warren Johnson Runs 6.714/207.50, Now #1
Kent with a lot of tire shake and clicked it off. Johnson has attended every National event here and was straight down the middle of the groove.
Left Lane: V. Gaines Runs 14.435/57.63, Now #4
Right Lane: Larry Morgan Runs 6.689/207.18, Now #1
Gaines like those in front of him with violent tire shake. Morgan goes No. 1 spot....Larry Morgan's incremental times: 60ft-1.009 sec., 330ft-2.803, 660ft-4.301/163.89 mph, 1,000ft-5.594.
Left Lane: Kurt Johnson Runs 6.744/206.64, Now #4
Right Lane: Ronnie Humphrey Runs 6.690/206.32, Now #2
Johnson with a little wiggle early, but he drives through it....Humphrey goes to the number two spot. Ronnie Humphrey's incremental times: 60ft-0.999 sec., 330ft-2.799, 660ft-4.297/164.03 mph, 1,000ft-5.592.
Left Lane: Ron Krisher Runs 6.658/207.56, Now #1
Right Lane: Shane Gray Runs 7.536/189.71, Now #7
Gray with tire shake and he clicks it off. Krisher with a great looking pass in the left lane to go to the number one spot. Ron Krisher's incremental times: 60ft-0.992 sec., 330ft-2.786, 660ft-4.281/164.83 mph, 1,000ft-5.569.
Left Lane: Allen Johnson Runs 6.723/208.39, Now #6
Right Lane: Rodger Brogdon Runs 6.722/206.54, Now #5
The first side-by-side drag race...Allen Johnson's incremental times: 60ft-1.030 sec., 330ft-2.845, 660ft-4.346/164.23 mph, 1,000ft-5.635.
Rodger Brogdon's incremental times: 60ft-1.018 sec., 330ft-2.823, 660ft-4.326/163.59 mph, 1,000ft-5.623.
Left Lane: Greg Stanfield Runs 6.723/206.48, Now #8
Right Lane: Vincent Nobile Runs 6.710/207.11, Now #4
Nobile made a move to wall but reeled it in to go to the number four spot. Stanfield gets in the show. Greg Stanfield's incremental times: 60ft-1.007 sec., 330ft-2.823, 660ft-4.331/163.55 mph, 1,000ft-5.627.
Left Lane: Erica Enders Runs 6.694/206.92, Now #5
Right Lane: Mike Edwards Runs 6.677/207.40, Now #2
Edwards with a real nice pass to go to the number two spot. Mike Edwards' incremental times: 60ft-1.009 sec., 330ft-2.808, 660ft-4.302/165.01 mph, 1,000ft-5.589. Enders with a real nice pass to move into the top half of the show.
Left Lane: Greg Anderson Runs 6.662/207.53, Now #3
Right Lane: Jason Line Runs 6.661/207.21, Now #2
These were side-by-side all the way down the track, but neither could catch Krisher. a couple good passes...Greg Anderson's incremental times: 60ft-0.998 sec., 330ft-2.792, 660ft-4.284/165.01 mph, 1,000ft-5.572.
Jason Line's incremental times: 60ft-0.998 sec., 330ft-2.786, 660ft-4.280/164.69 mph, 1,000ft-5.569.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old 10-14-2011, 06:11 PM
Round 2 Qualifying
Fri, 14 Oct 2011, 08:18 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
CHANDLER, Ariz. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 27th annual NHRA Arizona Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Shane Gray Runs 6.712/206.92, Now #9; Best prior run: 7.536/189.71, Was #15
Right Lane: Grace Howell No Time, Now #18; Best prior run: 23.253/26.24, Was #18
Weather conditions: air temperature 92 degrees, relative humidity 15 percent, barometer 28.52 inches, adjusted altitude 3,882 feet, track temperature 117 degrees.
Howell with a lot of tire spin right off the line and clicked it off and then came to a stop on the track before firing the car back up and driving off the track. She had got a no time before she fired up the car. Gray with a good pass this time to get in the show. Shane Gray's incremental times: 60ft-1.012 sec., 330ft-2.820, 660ft-4.320/163.95 mph, 1,000ft-5.616.
Left Lane: Gordie Rivera Runs 6.861/201.82, Now #15; Best prior run: 6.904/201.94, Was #15
Right Lane: Steve Kent Runs 14.921/55.68, Now #17; Best prior run: 17.660/44.85, Was #17
Kent spun the tires right off the starting line and clicked it off...Rivera improves on his previous run, but stays in the number 15 spot. Gordie Rivera's incremental times: 60ft-1.028 sec., 330ft-2.879, 660ft-4.415/160.44 mph, 1,000ft-5.738.
Left Lane: Rodger Brogdon Runs 6.737/205.94, Now #11; Best prior run: 6.722/206.54, Was #11
Right Lane: V. Gaines Runs 6.742/207.02, Now #14; Best prior run: 14.435/57.63, Was #16
Gaines gets down the track this time, but won't get in the show. V. Gaines' incremental times: 60ft-1.039 sec., 330ft-2.850, 660ft-4.353/163.71 mph, 1,000ft-5.647. Brogdon will not improve on his time from earlier today.
Left Lane: Warren Johnson Runs 7.847/129.65, Now #11; Best prior run: 6.714/207.50, Was #10
Right Lane: Kurt Johnson Runs 6.708/207.40, Now #8; Best prior run: 6.744/206.64, Was #15
WJ shook and clicked it off. Kurt with a real nice pass, the quickest pass of the round so far. Kurt Johnson's incremental times: 60ft-1.013 sec., 330ft-2.817, 660ft-4.320/163.63 mph, 1,000ft-5.615.
Left Lane: Vincent Nobile Runs 6.658/208.33, Now #1; Best prior run: 6.710/207.11, Was #9
Right Lane: Greg Stanfield Runs 15.466/54.23, Now #14; Best prior run: 6.723/206.48, Was #14
Stanfield spun the tires and pushed in the clutch. Noble launched hard and keep it hooked up to run the quickest pass of the round. Vincent Nobile's incremental times: 60ft-1.009 sec., 330ft-2.797, 660ft-4.287/165.36 mph, 1,000ft-5.572.
Left Lane: Ronnie Humphrey Runs 6.666/206.57, Now #5; Best prior run: 6.690/206.32, Was #7
Right Lane: Allen Johnson Runs 6.696/209.20, Now #9; Best prior run: 6.723/208.39, Was #13
Johnson improves on his pass from earlier today and gets in the show. Allen Johnson's incremental times: 60ft-1.030 sec., 330ft-2.833, 660ft-4.326/164.83 mph, 1,000ft-5.611. Humphrey moves up the ladder a couple spots with the second quickest pass of the round. Ronnie Humphrey's incremental times: 60ft-0.993 sec., 330ft-2.787, 660ft-4.281/164.63 mph, 1,000ft-5.571.
Left Lane: Larry Morgan Runs 6.669/207.05, Now #6; Best prior run: 6.689/207.18, Was #7
Right Lane: Erica Enders Runs 6.691/207.94, Now #8; Best prior run: 6.694/206.92, Was #8
Enders improves on her pass from earlier today, but will stay in the number eight spot. Erica Enders' incremental times: 60ft-1.011 sec., 330ft-2.813, 660ft-4.311/164.41 mph, 1,000ft-5.601. Morgan improves and moves up the ladder one spot. Larry Morgan's incremental times: 60ft-1.000 sec., 330ft-2.791, 660ft-4.286/164.57 mph, 1,000ft-5.577.
Left Lane: Mike Edwards Runs 6.642/209.10, Now #1; Best prior run: 6.677/207.40, Was #7
Right Lane: Greg Anderson Runs 6.969/161.88, Now #5; Best prior run: 6.662/207.53, Was #4
Edwards launched hard and keep it hooked up to go to the number one spot. Mike Edwards' incremental times: 60ft-0.991 sec., 330ft-2.785, 660ft-4.275/165.50 mph, 1,000ft-5.558. Anderson started drifting out of the groove and over by the wall before he lifted.
Left Lane: Jason Line Runs 6.642/207.11, Now #2; Best prior run: 6.661/207.21, Was #4
Right Lane: Ron Krisher Runs 6.665/207.75, Now #4; Best prior run: 6.658/207.56, Was #3
Krisher with another good pass, but slows from his earlier pass. Ron Krisher's incremental times: 60ft-0.988 sec., 330ft-2.783, 660ft-4.282/164.17 mph, 1,000ft-5.574. Line with a great pass and matches Edwards E.T. but will give up the No. 1 position based on speed. Jason Line's incremental times: 60ft-0.990 sec., 330ft-2.777, 660ft-4.266/165.23 mph, 1,000ft-5.552.
Old 10-15-2011, 02:31 PM
Round 3 Qualifying
Sat, 15 Oct 2011, 03:18 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
CHANDLER, Ariz. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 27th annual NHRA Arizona Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Grace Howell Runs 21.390/34.39, Now #13; No Prior Run
Right Lane: Warren Johnson Runs 6.740/207.46, Now #12; Best prior run: 6.714/207.50, Was #12
Weather conditions: air temperature 83 degrees, relative humidity 18 percent, barometer 28.64 inches, adjusted altitude 3,202 feet, track temperature 122 degrees.
Howell made a quick move toward the centerline and clicked it off. No help here for Johnson...
Left Lane: Greg Stanfield Runs 6.671/206.20, Now #8; No Prior Run
Right Lane: Gordie Rivera Runs 6.822/202.33, Now #14; No Prior Run
Rivera with his quickest pass of the weekend...Gordie Rivera's incremental times: 60ft-1.026 sec., 330ft-2.857, 660ft-4.382/161.44 mph, 1,000ft-5.701. Stanfield with his quickest pass of the weekend to get into the top half of the show. Greg Stanfield's incremental times: 60ft-0.995 sec., 330ft-2.786, 660ft-4.282/164.47 mph, 1,000ft-5.573.
Left Lane: Steve Kent Runs 6.677/206.39, Now #9; No Prior Run
Right Lane: Rodger Brogdon Runs 6.712/206.86, Now #14; No Prior Run
Brogdon with his quickest pass of the weekend to get into the show. Rodger Brogdon's incremental times: 60ft-1.010 sec., 330ft-2.822, 660ft-4.323/164.17 mph, 1,000ft-5.616. Kent with his quickest pass of the weekend to get in the show at the number nine spot. Steve Kent's incremental times: 60ft-1.000 sec., 330ft-2.792, 660ft-4.286/164.31 mph, 1,000ft-5.580.
Left Lane: Greg Anderson Runs 6.635/208.26, Now #1; Best prior run: 6.662/207.53, Was #5
Right Lane: Shane Gray Runs 6.993/175.94, Now #13; Best prior run: 6.712/206.92, Was #13
Gray with hs quickest pass of the weekend, but will stay in the number 13 spot. Shane Gray's incremental times: 60ft-1.011 sec., 330ft-2.864, 660ft-4.420/158.13 mph, 1,000ft-5.772. Anderson launched hard and keep it hooked up to go to the number one spot. Greg Anderson's incremental times: 60ft-0.989 sec., 330ft-2.777, 660ft-4.265/165.29 mph, 1,000ft-5.549.
Left Lane: V. Gaines Runs 6.694/207.02, Now #11; No Prior Run
Right Lane: Larry Morgan Runs 6.662/207.34, Now #6; Best prior run: 6.669/207.05, Was #7
Gaines with his quickest pass of the weekend to get in the show. V. Gaines' incremental times: 60ft-1.017 sec., 330ft-2.813, 660ft-4.309/164.25 mph, 1,000ft-5.601. Morgan with his quickest pass of the weekend to move up the ladder one spot. Larry Morgan's incremental times: 60ft-1.001 sec., 330ft-2.787, 660ft-4.280/164.63 mph, 1,000ft-5.570.
Left Lane: Kurt Johnson Runs 12.977/94.92, Now #13; Best prior run: 6.708/207.40, Was #13
Right Lane: Ronnie Humphrey Runs 6.650/207.53, Now #4; Best prior run: 6.666/206.57, Was #7
Johnson with severe tire shake and clicked it off. Humphrey with a great pass the second quickest pass of the session to go to the number four spot. Ronnie Humphrey's incremental times: 60ft-0.993 sec., 330ft-2.780, 660ft-4.270/164.89 mph, 1,000ft-5.557.
Left Lane: Allen Johnson Runs 6.646/209.26, Now #4; Best prior run: 6.696/209.20, Was #12
Right Lane: Vincent Nobile Runs 6.684/208.07, Now #6; Best prior run: 6.658/208.33, Was #5
Jim Yates is helping the Allen Johnson team now...Johnson launched hard and runs the second quickest pass of the weekend to go to the number four spot. Allen Johnson's incremental times: 60ft-1.006 sec., 330ft-2.794, 660ft-4.282/165.58 mph, 1,000ft-5.563. Nobile with another good pass, but will not improve. Vincent Nobile's incremental times: 60ft-1.014 sec., 330ft-2.811, 660ft-4.305/164.65 mph, 1,000ft-5.594.
Left Lane: Erica Enders Runs 6.638/208.33, Now #3; Best prior run: 6.691/207.94, Was #11
Right Lane: Jason Line Runs 6.620/208.55, Now #1; Best prior run: 6.642/207.11, Was #3
This was a great drag race as Enders runs the third quickest pass of the round to go to the number three spot. Erica Enders' incremental times: 60ft-0.987 sec., 330ft-2.777, 660ft-4.267/165.05 mph, 1,000ft-5.552. Line launched hard and keep it hooked up to go to the number one spot. Erica Enders' incremental times: 60ft-0.987 sec., 330ft-2.777, 660ft-4.267/165.05 mph, 1,000ft-5.552.
Left Lane: Ron Krisher Runs 6.640/208.26, Now #5; Best prior run: 6.658/207.56, Was #8
Right Lane: Mike Edwards Runs 6.617/210.28, Now #1; Best prior run: 6.642/209.10, Was #4
Edwards with another great pass, straight down the groove to go to the number one spot. Mike Edwards' incremental times: 60ft-1.004 sec., 330ft-2.784, 660ft-4.265/166.17 mph, 1,000ft-5.539. Krisher with his quickest pass of the weekend to move up the ladder three spots. Ron Krisher's incremental times: 60ft-0.990 sec., 330ft-2.780, 660ft-4.271/165.38 mph, 1,000ft-5.554.
Old 10-15-2011, 02:38 PM
Final Qualifying
Sat, 15 Oct 2011, 05:32 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
CHANDLER, Ariz. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 27th annual NHRA Arizona Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Gordie Rivera No Time, Now #17; Best prior run: 6.822/202.33, Was #17
Right Lane: Grace Howell Runs 7.471/149.12, Now #18; Best prior run: 21.390/34.39, Was #18
Weather conditions: air temperature 91 degrees, relative humidity 15 percent, barometer 28.56 inches, adjusted altitude 3,799 feet, track temperature 126 degrees.
Rivera was a no show. Howell with a nice straight pass until around 1000 feet and pushed in the clutch.
Left Lane: Warren Johnson Runs 6.738/206.92, Now #16; Best prior run: 6.714/207.50, Was #16
Right Lane: Kurt Johnson Runs 6.693/206.80, Now #12; Best prior run: 6.708/207.40, Was #13
Kurt with his quickest pass of the weekend...Kurt Johnson's incremental times: 60ft-0.999 sec., 330ft-2.798, 660ft-4.302/163.77 mph, 1,000ft-5.598. no help here for Warren and he will start from the No. 16 position.
Left Lane: Rodger Brogdon Runs 6.668/206.13, Now #10; Best prior run: 6.712/206.86, Was #15
Right Lane: V. Gaines Runs 6.712/207.43, Now #14; Best prior run: 6.694/207.02, Was #13
No help here for Gaines. Brogdon with his quickest pass of the weekend and moves up to the No. 10 position.
Left Lane: Shane Gray Runs 12.394/69.51, Now #15; Best prior run: 6.712/206.92, Was #15
Right Lane: Steve Kent Runs 6.688/207.30, Now #12; Best prior run: 6.677/206.39, Was #12
Gray with violent tire shake right at the hit. Kent with another good pass, but will not improve. Steve Kent's incremental times: 60ft-1.007 sec., 330ft-2.801, 660ft-4.299/164.17 mph, 1,000ft-5.593.
Left Lane: Larry Morgan Runs 6.685/207.18, Now #9; Best prior run: 6.662/207.34, Was #9
Right Lane: Greg Stanfield Runs 6.688/207.53, Now #11; Best prior run: 6.671/206.20, Was #11
Neither car improves...Larry Morgan's incremental times: 60ft-1.011 sec., 330ft-2.804, 660ft-4.301/163.93 mph, 1,000ft-5.592.
Greg Stanfield's incremental times: 60ft-1.007 sec., 330ft-2.803, 660ft-4.302/164.19 mph, 1,000ft-5.594.
Left Lane: Vincent Nobile No Time, Now #8; Best prior run: 6.658/208.33, Was #8
Right Lane: Allen Johnson Runs 6.652/209.01, Now #6; Best prior run: 6.646/209.26, Was #6
Nobile's car won't start and is pushed off the starting line. Johnson with the quickest pass of the round. Allen Johnson's incremental times: 60ft-0.999 sec., 330ft-2.790, 660ft-4.281/165.05 mph, 1,000ft-5.566.
Left Lane: Ronnie Humphrey Runs 6.770/205.13, Now #7; Best prior run: 6.650/207.53, Was #7
Right Lane: Ron Krisher Runs 6.668/207.82, Now #5; Best prior run: 6.640/208.26, Was #5
Humphrey slows from his earlier runs. Krisher with the second quickest pass of the round. Ron Krisher's incremental times: 60ft-0.991 sec., 330ft-2.787, 660ft-4.284/164.35 mph, 1,000ft-5.575.
Left Lane: Jason Line Runs 6.648/206.89, Now #2; Best prior run: 6.620/208.55, Was #2
Right Lane: Erica Enders Runs 6.670/207.78, Now #4; Best prior run: 6.638/208.33, Was #4
Enders with a nice pass, but won't improve. Erica Enders' incremental times: 60ft-0.996 sec., 330ft-2.791, 660ft-4.287/164.51 mph, 1,000ft-5.578. Line with the quickest of the round, but will stay No. 2 for now. Jason Line's incremental times: 60ft-0.996 sec., 330ft-2.780, 660ft-4.269/165.13 mph, 1,000ft-5.556.
Left Lane: Mike Edwards Runs 13.463/55.08, Now #1; Best prior run: 6.617/210.28, Was #1
Right Lane: Greg Anderson Runs 6.663/207.75, Now #3; Best prior run: 6.635/208.26, Was #3
Edwards with violent tire shake and pushes in the clutch. Anderson with the third quickest pass of the round. Greg Anderson's incremental times: 60ft-0.989 sec., 330ft-2.783, 660ft-4.279/164.41 mph, 1,000ft-5.570.
Old 10-17-2011, 10:05 AM
Summary of Eliminations
Sun, 16 Oct 2011, 08:56 PM
Summary of Eliminations in Pro Stock
CHANDLER, Ariz. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 27th annual NHRA Arizona Nationals:
Round 1:
Vincent Nobile, Dix Hills NY, '11 Avenger, Right lane, (0.006) 6.657 209.56 def. Larry Morgan,Newark OH, '11 Mustang, (0.017) 10.793 72.37
Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.025) 6.698 207.69 def. Ronnie Humphrey,Jacksonville NC, '09 GXP, (0.130) DQ-Centerline
Erica Enders, New Orleans LA, '10 Cobalt, Right lane, (0.010) 6.659 208.91 def. Kurt Johnson, SugarHill GA, '09 GXP, (0.040) 6.719 206.86
Allen Johnson, Greeneville TN, '11 Avenger, Right lane, (0.020) 6.653 209.59 def. Greg Stanfield,Bossier City LA, '09 GXP, (0.029) 6.661 207.88
V. Gaines, Lakewood CO, '11 Avenger, Left lane, (0.104) 6.711 208.07 def. Greg Anderson,Mooresville NC, '09 GXP, NT-Broke Before Staging
Mike Edwards, Coweta OK, '09 GXP, Right lane, (0.042) 6.612 210.11 def. Warren Johnson, Sugar HillGA, '09 GXP, (0.097) 6.718 206.95
Shane Gray, Denver NC, '09 GXP, Left lane, (0.032) 6.727 207.11 def. Jason Line, Mooresville NC,'09 GXP, (0.065) 7.021 177.14
Steve Kent, Lottie LA, '09 GXP, Left lane, (0.099) 6.664 208.17 def. Ron Krisher, Warren OH, '09GXP, (0.154) 6.653 209.33
Round 2:
R Brogdon, Right lane, (0.045) 6.714 207.30 def. S Gray, (0.011) 7.004 204.57
E Enders, Right lane, (0.017) 6.683 207.46 def. S Kent, (0.021) 6.690 206.42
A Johnson, Right lane, (0.028) 6.664 209.20 def. V Gaines, (0.078) 10.677 83.00
V Nobile, Left lane, (0.025) 6.696 207.85 def. M Edwards, (0.038) 6.768 208.97
Round 3:
V Nobile, Left lane, (0.012) 6.684 208.46 def. E Enders, (0.015) 14.023 60.52
A Johnson, Right lane, (0.040) 6.662 209.36 def. R Brogdon, (0.035) 6.700 206.13
Round 4:
V Nobile, Left lane, (0.009) 6.678 208.30 def. A Johnson, (0.034) 6.655 209.49
Low ET: Mike Edwards 6.612 seconds
Top Speed: Mike Edwards 210.28 MPH
MReeves
Stock Eliminator
11-06-2019 11:21 AM
MReeves
Funny Car
10-17-2011 10:15 AM
MReeves
Super Stock
10-16-2011 02:43 PM
MReeves
Super Gas
10-15-2011 03:42 PM
MReeves
Pro-Stock
02-23-2010 04:57 PM
Quick Reply: NHRA Arizona Nationals Phoenix
