318 Poly missing Valve Lash Adjusters HELP!
2 Attachment(s)
Hi there, i recently swapped a 318 poly into my 67 dodge d200 that had a slant six and I just got it runni g good enough to drive.
Anyways, i went to adjust the valves on it, and after pulling the valve covers, there was no studs or anything for adjusting the valve clearances. I was stumped and now I am wondering how i am supposed to adjust them? Or if i even can and why it was no studs or screws? Ill post a pic below so you all know what im getting at here. Any help is appreciated. Thanks! |
My guess would be that you have hydrolic lifters no adjustment needed.. Check clearance when the valve is closed
I dont remember how the poly's got adjusted.... If memorie serves me rite? I thought they used valve stem caps to take up clearance on them old dogs?
I think some guys went to adjustable push rods or rocker arms from a later poly motor... Sorry. |
did you find out to adjust i have a 65 poly
