400B BB build up
Old 12-13-2011, 01:41 PM
Kent Esau's Avatar
400B BB build up
Hello to all, I am new here and very interested in making this my main source of info. I have built quite a few diesel engines but never a gas much less a mopar. I aquired my Grandpa's pk when he passed away, it is an Adventurer 150 with a 400 BB in it, I have it out and am wanting to build a 500+ motor. I am open to anything anyone has to say. I cant say that money is NOT an issue but it is not primary, I have enough to play a little.
Old 12-13-2011, 04:12 PM
Check out a stroker kit !! www.440source.com , Hughes engines, Mancini racing many places that offer kits If it is in the budget maybe a set of aluminum heads.. Just keep the compression reasonable to run pump gas for a street motor. Most important thing is to talk to an experienced Mopar engine builder not your Chevy friends..
Old 12-13-2011, 08:41 PM
Cheapest most proven stroker for a 400 is a 440 crank with the mains turned down to a 400 main size and the rods journals turned down to a Chevy rod journal size. Some good after market rods available for that combo. I would use Muscle Motors for a stroker kit. They only do Mopars.
http://www.musclemotorsracing.com/
Old 12-14-2011, 06:25 AM
Kent Esau's Avatar
Thanks for the comments, I am researching the links now.
Old 12-14-2011, 06:27 AM
Kent Esau's Avatar
Low diff.
The pk I have has a very low rearend in it, I am wondering what my best options are for getting something that cruises at 65mph without being on the redline, its really bad.
Old 12-14-2011, 07:01 PM
scotts74birds's Avatar
A p/u has plenty of room for an overdrive! Larger tires will also effectively lower your gear ratio. If it isn't 4wd, then changing the cogs shouldn't be to pricey.
Old 12-17-2011, 02:20 PM
bboogieart's Avatar
Not sure what is meant by PK but I am guessing the "adventurer 150" is for a 70's 1/2 ton truck(?)
As mentioned taller tires. Rear gears or an overdrive from a newer truck.
Got any more info or pictures.
TKK
08-10-2011 06:45 PM
TCPMeta
04-03-2009 06:52 PM
73DartSport
03-06-2008 04:02 PM
runninbird
01-29-2008 11:56 AM
rubadub
11-11-2007 02:02 AM
Quick Reply: 400B BB build up
