67 Charger door panel removal help!
Old 10-06-2023, 12:41 PM
Captainatom11's Avatar
Hi everyone, I'm a newbie at all of this so I hope you'll bare with me. So I got my dream car a while back, it a 67 Charger. However after some bad luck I'm going to have to do quite a bit of the work on it myself. The car needs to have the door handles, and door locks replaced. I also need to install new side mirrors. I'm also thinking of cutting some wholes so I can install some aftermarket speakers. So first things first I need to take the interior door panels off but I can't seem to find any references on how to do it. If anyone can help me out with some guidance and pictures it would be greatly appreciated!
Old 10-06-2023, 04:08 PM
Not a great removal video... But you can get an idea what you need to do in a reverse patter,,,,, Cheers
Old 10-08-2023, 02:55 AM
https://www.youtube.com/watch?v=-8TezeZu5ns
​So I watched the video, but what I'm still not clear on is how do I actually take the door panels off.
Old 10-08-2023, 09:54 AM
Kuvasz101's Avatar
The video at the 7:10 minute mark barely catches the clip springs that are attached to the panel. If you look closely they're there. To remove the panel slide a screwdriver the wider the better or a putty knife under the panel clips and pry outwards pulling the panel from the door. Once you pop one off you'll get the rest to follow, but use the tools mentioned. When you put the speakers in make sure the wires don't get caught in the regulator when cranking up the window.
Old 10-08-2023, 10:57 AM
Unscrew the door opening handle... Unscrew the armrest.... Unscrew the door glass handles... Unscrew the outside rearview mirror nut....
Follow the clip removal process as mentioned below... Be careful and try not to rip the clip fastener out of the old cardboard that the panel is made of. Work as close to the clip as you can.
Keep us posted on how you do...
Old 10-08-2023, 12:23 PM
Hey thanks everyone. I appreciate all the help. I'll reply back in a couple weeks once I have all the new parts and start the work!
Tinmacdaddy
08-31-2022 11:58 AM
Anthony Turner
11-04-2017 10:47 AM
ahrkar
09-25-2014 08:20 PM
icecat66
12-07-2013 08:09 AM
72chargerSE
11-22-2010 02:20 PM
Quick Reply: 67 Charger door panel removal help!
