Go Back   Mopar Forums > GENERAL > Do-It-yourself Section
Thread Tools Display Modes
Old 01-15-2008, 10:41 PM   #1 (permalink)
sinister
Junior Member
Talking 69 DODGE DART 340
Hi all I am getting a 69 dart with 340 in a week and would like to know some general info on it..I have never owned a dart but have wanted one since I was about 7 years old and im now 27..So if any one can help me with some general info I should know please do.such as the pros and cons to the 340 motor vs the 440 and some info that I should know about the 340 motor and so on..Thanks very much...Steve
sinister is offline   Reply With Quote
Old 01-16-2008, 09:42 AM   #2 (permalink)
440roadrunner
Senior Member
What's to know? Your question is so general that it's hard to give you an answer.
About the only down side to 340s is if you start to build them to very high horsepower ratings. They don't have enough head bolts, and you must use special bolts, "O ring" the cylinders for better gasket seal, and do some modifications to the oil system.
For the averag guy, building to 350-400HP this should be be an issue.
If you go searching for parts, like, say, you blow up a trans, you want to be a little careful. 360 engines are "externally balanced" and if you have a 4 speed, that means the flywheel is balanced different between the two engines. If you have an auto, either the flex plate, or the converter is balanced different for the 360.
I ran a 340 for several years in my '70 RR---I put it there, Chrysler didn't--and it was a great combo.
I don't remember if '69s came with aluminum single point or dual point ignition. If you have a stock Chrysler (aluminum) distributor, either get a cast iron dual point, an aftermarket like Accell, or better yet, electronic.
Your '69 should have come with a "square bore" Carter AVS/AFB. These are great carbs. You can buy aftermarket replacements, I believe through Edlebrock.
Don't be too darn quick to chop this all up and build it or customize it. Stock 340 cars have gone up tremendously in value the last few years. When you add up the vast quantity of Mopar muscle cars, there just weren't many 340s built.
440roadrunner is offline   Reply With Quote
Old 01-16-2008, 08:46 PM   #3 (permalink)
sinister
Junior Member
69 dart 340
Hi Thanks for the info,it is all good info for me as I didnt know any of it.One thing do you know what the HP is in a stock 340 ? and what is the best things to do to give it more HP? For this is all new to me and im really wanting to learn,for I finally am getting the car ive wanted for years..Thanks for replying..Steve
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
are there any Dodge Dart forums? kmn5 A-Body 10 10-20-2008 10:29 PM
69 dodge dart gt trt100 General Discussion 4 01-14-2008 10:36 PM
For Sale: '74 Dodge Dart 4dr Desolate A-Body 1 11-13-2007 04:59 PM
FS: 1960 Dodge Phoenix Dart tinascars Mopar Classifieds 0 11-06-2007 12:23 PM
73 dodge dart swinger sanders06 A-Body 2 11-05-2007 05:57 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
