distributorless 440
distributorless 440
Iam wondering if anyone has adapted a newer style distributorless ignition system to a 440.something simular to the newer hemis with indivual coils for each cylinder. is there a kit that any one sells?
Yes, IIRC,
Electromotive, FAST, compu-tronix, Holley(?), to name a few, offer a DIS system for BB Chryslers, using LS style coil set-ups or something similar, very cool stuff.
Last I heard MSD is not offering a DIS system for BBM's...yet, might change but only they know...
Thanks I've done a lot of research to make it all work. I know a lot of guys will hate me for putting a GM 4l60e trans in the car but I needed a overdrive trans that can handle the power it will put out.
Have you had it running yet?
My under standing was. It is most difficult to get the Crank Ring Phased properly. I forget how many teeth worked best? "43-48" or something like that. And there was something about to much noise being picked up causing some miss fire issues...
Hope yours works out nice.... I'm sure there will be a great call out for them.
Have you had time to figure out the H.P. range it will cover? or is it still a little early for that info?
I'm running a 36 tooth reluctor wheel with an LS1 xim box swaping the wires so I have a 440 fireing order. Noise shouldn't be a issue with this set up. With the fast xfi it won't be a problem to tune you put the values of the sensors in and where they're at and where you want your timing to be. They have a nice setup or holley dominator is a good one also for doing this. The holley has a trans controler for a GM trans if your putting a 4l80e or 4l60e in your mopar. It's just like tuning an LS engine. The H.P should be about 650 and 900 with nitrous. My plan is to have a 9 second street car I can drive anywhere.
