Sponsored by:
Sponsored by:
225 to 318 Swap
Old 09-13-2008, 07:11 PM
Junior Member
fpereira23's Avatar
225 to 318 Swap
Hi Guys,
I think I finaly found the engine to swap the 225 in my 69 Dart.
I found a 73 Coronet with a 318. I'm buying the whole car for $500. I was planning on using the engine and transmision, however I've been told that the coronet's crossmember will bolt right into the Dart so that I won't need the Schumacher engine mounts....Is this True???
Also, will I also need to use the drive shaft and rear end? Will this be a good idea or should I stay with the Dart's ones. Will they fit or will I need to modify something in my Dart?
What other part do you think I could use from this 73 Coronet on my 69 Dart? Steering...etc??
TKS
Old 09-14-2008, 09:42 AM
Senior Member
ef8340's Avatar
doc is correct the k-frame wont interchange the motor and trans will, also some lightbulbs and fuses,& cig lighter, the driveshaft and rear will be different aswell and wont bolt up
SspazZ
07-29-2014 03:35 PM
Arich
05-25-2012 12:28 PM
225valiant440
07-16-2011 09:55 AM
mrblond750
06-23-2010 05:55 PM
MuscleCrazy
02-22-2009 01:54 PM
Quick Reply: 225 to 318 Swap
