Sponsored by:
Sponsored by:
318 with 360 heads?
Old 05-26-2009, 10:07 AM
The R/t 360s came with a mild cam in them. If the cam in the motor that you are pulling out is still good, install it into the block that you are installing. Port and polish the heads, get an M1 intake as it will flow better than the stock dome intakes.
Why do you want to pull the motor that is in there and install a 318 with 360 heads?
Old 05-26-2009, 11:02 AM
Senior Member
craveman's Avatar
dont forget the compression drop from the bigger combustion chamber in the 360 heads as well. however the old 318 cop cars had this setup for the added airflow.
Old 05-26-2009, 07:20 PM
Senior Member
craveman's Avatar
good deal. wont be as much power though
afro
09-02-2011 12:33 PM
vengence99
05-27-2011 06:14 PM
recondotexas
12-31-2009 10:12 AM
1973charger
06-04-2009 09:46 AM
devilkin4
05-23-2009 12:31 AM
Quick Reply: 318 with 360 heads?
