Sponsored by:
Sponsored by:
318 to 360 swap
Old 09-07-2008, 06:21 PM
Commando's Avatar
That all depends on your level of skill as a mechanic.
It's not too difficult with some of the older cars as there is a lot of space to work with.
Just my opinion, maybe someone who has done this can help you.
Old 09-08-2008, 12:57 AM
are the 318 and 360 both magnum motors or are both LA motors? If the 318 is a magnum motor and the 360 is a LA motor then not much, if anything, is going to fit between the two.
Old 09-08-2008, 02:05 PM
keep it EFI for better start up, better throttle response, less time dealing with adjustments. its just easier and better than carb for daily and winter driving.
Old 09-08-2008, 05:03 PM
challenger's Avatar
do as 78d200 says and keep the efi and after installing it i would get some shorty headers to keep a little room between fender wells
Old 09-09-2008, 01:14 AM
is the 360 a magnum motor or a LA motor? the head configurations are different.
Old 09-09-2008, 07:22 AM
as long as both motors are magnum motors then yes, the 318 EFI will work on the 360.
Old 09-10-2008, 01:25 AM
92 and up the 239s and 318s are magnums. 93 and up the 360s are magnums. you should be all set then.
Old 12-18-2010, 02:35 PM
BadMoose's Avatar
I did the 318 to 360 swap a few years back in a '84 RamCharger.
I ran into a problem when I used the 318 flex plate and converter with the 360 motor.
They are different or were different. Internally balanced vs: externally balanced.
Dont know if this holds true on the newer motors or not but would beleive it does. And is something you might want to check out.
Old 12-18-2010, 04:31 PM
Silverick's Avatar
The EFI will also compensate for altitude change.
I live at sea level in California and a trip to the mountains or to Hot August Nights in Reno in a carbureted car, means that the car will run rich and totally lose power without carb adjustments to compensate for the thinner air.
The 318 Magnum to 360 Magnum should be a pretty basic swap.
Old 12-20-2010, 02:30 AM
This is true for the LA motors. I believe the Magnum motors are both the exact same minus C.I.
jej
11-17-2014 07:59 AM
notta _mech
09-13-2011 09:42 AM
keith811
01-13-2011 10:43 AM
mlithgow
11-26-2008 02:15 AM
1982dodgeram
11-23-2008 02:42 AM
Quick Reply: 318 to 360 swap
