4 speed
on
4 speed
Ok guys I have some questions I have a 440 and a 4 speed I want to put in my 1970 plymout fury iiiwhich currently has a 318 and a 727 . ? The 4 speed is a b body transmission I believe will this work for me and will the b body cluch/brake pedal *** work any info is very much appricated
the fury is a c body. Will the engine and transmission fit yes with c body mounting brackets. Will the clutch pedal fit no. You need the clutch bolt on bracket that goes beside the steering bracket from a cbody as well as the brake pedal.
None of the b body linkage will fit either.
The engine and trans will bolt right in. Clutch linkage and pedals will need to be replaced with manual shift parts or heavily modified by a competent welder/fabricator.
red2bunkeru
02-27-2009 02:25 PM
