440 crank/rod question
Old 07-07-2011, 09:13 AM
69POLARA383's Avatar
Bought a steel crank today that has been turned .010 on both ends, factory 3.75 stroke. My questions being the rookie I am is what do I have to do if anything to make sure the rods and bearings go in all ok?? SInce its turned .010 do I need to get anything else machined or bigger bearings or can I still use for example stock 440 6 pack rods?
Old 07-07-2011, 10:15 PM
I run a steel/forged crank from a 1973 motorhome block...the six pack rods are beefy...people complain about them because they weight a ton and do not spin up to high rpm as with lighter rods...who gives a crap...shot peen them...re-size them and put some ARP wavelock bolts in them and your done...nothing wrong with spinning the crank .010...if the rod and mains are turned .010 then you will need to get .010 over sized bearings for the mains and the rods
Old 07-10-2011, 09:47 PM
Mr. Belvedere II's Avatar
Yes, you'll need to have your rods resized at the machine shop, and the corresponding bearings to fit with the machine work thats been done. The machine shop guys will help you out. Get to know them well.That steel crank is a good investment. Freakin' bomb proof. Have fun.
Old 07-10-2011, 10:04 PM
Balancing is different between stock rods and 6 pac rods make sure to
get the correct parts -- Harmonic balancer and trans converter
Erikthegoalie
04-10-2010 05:26 AM
Dave E
12-14-2009 07:01 AM
rcknrolfender79
12-01-2009 02:14 AM
atowncris
11-19-2009 12:48 PM
1973charger
06-04-2009 11:40 AM
Quick Reply: 440 crank/rod question
