Big cam low vaccum
Old 04-16-2018, 05:49 PM
etweeks's Avatar
Big cam low vaccum
HI Have 69 charger 440 low vaccum I need to add vane style power brake booster any suggestions on which would be the best cvr leeds or master power ? Thanks for any info.
Old 04-16-2018, 07:36 PM
Are you sure you need that much vacuum? Or will a canister with another check valve work ok?
https://barkerengines.com/product/br...powder-coated/
etweeks (04-17-2018)
Old 04-17-2018, 09:10 AM
etweeks's Avatar
Good Morning Bob, I don't know if another canister would help I only have 13" of pressure at the manifold it should 15" at bare minimum 18" to 22" would be great. The power brake's are rock hard know. Thanks Thomas
Old 04-17-2018, 11:26 AM
How about an electric vacuum pump Check with Summit racing
Old 04-17-2018, 12:03 PM
etweeks's Avatar
Thanks that's my next option Can't figure which none to buy?
Old 04-17-2018, 01:25 PM
My son likes the ones in the newer Mustangs.
Old 04-17-2018, 08:43 PM
http://ssbrakes.com/i-10093987-elect...ist-28146.html
Old 05-30-2018, 04:29 AM
ZEN357's Avatar
I would go with another canister and vacuum pump for the camshaft.
etweeks (05-30-2018)
Old 05-30-2018, 06:01 AM
Archer's Avatar
Thomas -
I've been running about 12" at idle for the last 40 years on my 440 and have no problems with the breaks or anything else that's vac assisted.
If you're having issues, something else is going on.
BTW - I have a vac gauge on my instrument cluster, so I know exactly what the pressure is in real time.
Old 05-30-2018, 11:49 AM
etweeks's Avatar
low vacuum
Thanks I went to vane style vacuum pump it seems to help. Thomas
DieselJeep
09-27-2018 08:22 AM
etweeks
Member question and comments about MoparForums.com
04-16-2018 07:36 PM
Coronet 500
10-09-2013 02:50 PM
lunati318
04-12-2011 02:39 PM
Monaco383
07-16-2009 12:53 PM
Quick Reply: Big cam low vaccum
