A BODY REAR END?
Old 06-15-2009, 09:50 AM
67rockabillydart's Avatar
A BODY REAR END?
Ok i have a 67 dart that came with a slant six.. im doing a small block engine swap and i need to know what rear end does it have? how can i tell if i have a 7 1/4 or 8 3/4? has anyone else done this swap? cause i may have more questions if you have...
Old 06-15-2009, 10:15 AM
thinkin with me dipstick
johnthegoalie's Avatar
7-1/4 wimpy wimpy wimpy
8-3/4 HEFTY HEFTY HEFTY
look at the back, are there bolts - if bolts 7-1/4
if you are having trouble finding a reasonable 3/4 - look into the 8-1/4, they are plenty strong and relatively inexpensive to build up
Old 06-15-2009, 10:28 AM
blue 68 gts's Avatar
My Dart had a 7 1/4 in it. Toss it.
You'll know the diff between a 7 1/4 and an 8 3/4. Like John basically said... an 8 3/4 will look WAY bigger.
An 8 3/4 is home in the a-bodys
Old 06-15-2009, 10:59 AM
Crazy4Carz.Com's Avatar
Don't be afraid of a B body rear. Only about an inch longer.
Old 06-15-2009, 01:50 PM
the back of a 8 3/4 is welded
Old 06-18-2009, 08:07 AM
OK, thanks i will look at that next time i work on the car, from the sound of it looks like im going to change it... has any one tried using a ford 8 inch rear end? i know my buddy has a spare i wonder if it will work?
Old 06-18-2009, 09:01 AM
Anything can be put in anything....BUT!...This is like the Chevy motor transplant discussed here a while back. Please keep your Mopar all Mopar. It will be easier, and worth more later.
Old 06-18-2009, 09:24 AM
X2!
Old 06-18-2009, 04:31 PM
3x
Old 06-18-2009, 07:38 PM
theomahamoparguy's Avatar
how about a rearend out of a jeep?? not sure how wide they are but some of them look fairly narrow. Im sure some of them are 8 1/4 mopar rears .
The best part of using the jeep rear is that it has the same bolt pattern and the
"register" on the end of the axle is the same as the old mopar cars [with 4 1/2 bolt pattern]. {this is only advice if you change up to the larger 4 1/2 bolt patt. which is much stronger btw} AND
Old 06-19-2009, 02:11 AM
Most of the CJs came with AMC 20 rear axles that are a 2 piece shaft. there are kit out there that replace the shafts with a 1 piece. Otherwise you are looking at a dana 35 c-clip (some came non-c-clip) and dana 44 which is a semi floating. I'm not sure about the widths of them, but can find out easily enough if you want. If anything, I would cut down a D44 and have some shafts made up for it as parts are cheap and all over the place for them........ if you were to go that way. Plus with the tire size that are run on these cars, you wouldn't really have to worry about it breaking. (maybe i'll see about installing one in the Valiant now that we are talking about it)
If you want any info on jeep axles, ask away.
Old 06-22-2009, 09:04 AM
TRUE... i'll have to try and find a good 8 3/4 then....
68hemidart
01-16-2014 05:59 AM
maynardc69
07-27-2013 12:15 PM
68hemidart
05-15-2013 02:19 PM
moparcharlie
03-29-2011 03:59 AM
MoparMan76
01-10-2011 12:42 PM
Quick Reply: A BODY REAR END?
