Do you think I can take him? Chevy vs Mopar
Old 04-30-2009, 01:55 AM
you should be able to take him. It might be close but if you can get everything to work together, then it should be no prbolem.
Old 04-30-2009, 02:37 AM
BuckNeccid's Avatar
Good luck, let us know how it works out. I agree with 78 and you.... You may take him, it's gonna be close, and watch the slippage. Practice as much as you can LEAVING, before the race, less attention on winning, get off the line fast and without slippage. Most races are won by who leaves first.
Old 04-30-2009, 11:04 AM
Little Demon
Red Devil's Avatar
all about reaction time there, if you tree him you can win easy
Old 05-01-2009, 03:12 PM
agreed
make sure you hook, and you got him
Old 05-01-2009, 03:23 PM
pjmopar's Avatar
Yup ,leave on the last yellow light and watch him in your rear view mirror
Old 05-03-2009, 03:06 PM
blue 68 gts's Avatar
Take the traction bars off though...
-nick
Old 05-03-2009, 07:15 PM
Well? How did it go?
Old 05-04-2009, 03:11 PM
Times and speed?
Old 05-04-2009, 03:25 PM
wouldnt the traction bars help?
Old 05-04-2009, 05:29 PM
Little Demon
Red Devil's Avatar
hmm?? I did a search on that and I found an article in muscle car review that said traditionally mopar guys have know to not run traction bars. the article said that mopars were known to run better with a pinion snubber, rather than traction bars. What is a pinion snubber?
Old 05-04-2009, 05:50 PM
It is like a bump stop that is above where the pinion comes through the housing and helps to keep the axle from twisting upward.
Old 05-04-2009, 05:53 PM
Little Demon
Red Devil's Avatar
oh ok, thanks Tim
Old 05-04-2009, 08:06 PM
Crazy4Carz.Com's Avatar
Look at my other post on your other thread about (15's) and you can learn a little about hp, and MPH.
Good luck.
Old 05-05-2009, 05:03 AM
rr69half6bbl's Avatar
LOL figures, the chubbie guys always talk smart till you put the car on the track, ive seen very few come through , and then most still get the beat down. On traction bars, the front of the leaf springs on a mope are designed to finger out or spread open if you will , this allows for a small percentage of axle wind up, this is when the torques being applied, the axle wants to lift up, but the springs counter act that forcing it to stay down, and when you put t- bars on they clamp down the front of the springs stopping the down ward force, the pinion snubber is the metal plate on top of the center section on the rear above where the drive shaft bolts on, they make a snubber with an adj. top so you can limit the amount of up travel the rear does go.
Old 05-05-2009, 01:54 PM
so, both of these would help you 1/4 times, wouldnt they?
Old 05-05-2009, 03:03 PM
Little Demon
Red Devil's Avatar
idk, I just read in that magazine that mopar guys have been known to favor the pinion snubber over the traction bars, it didn't say why
Old 05-07-2009, 05:34 PM
must have something to do with leaf springs
Old 02-12-2011, 06:10 PM
dr.mopar's Avatar
So if traction bars don't work on Mopars then explain why Mr. Norms shop installed traction bars & a pinion snubber on his projects cars??
68Polara500
02-02-2012 09:09 PM
palerider508
06-23-2011 03:09 AM
914mopar
07-25-2010 06:01 PM
Erikthegoalie
03-16-2007 10:54 AM
Quick Reply: Do you think I can take him? Chevy vs Mopar
