Sponsored by:
Sponsored by:
Drums won't go back on..
Old 06-03-2010, 09:43 PM
RROriginals's Avatar
Well I pulled my drums off, ordered new pads + shoes, new drums, new hardware kit, everything.
I've changed all the springs, wheel cylinders, pretty much everything is new. So I put both sides together but I go to put my drums on, they will NOT fit.
My new drums are actually a little bigger than my old ones but they won't go back on, so the size is not the problem, I don't think my parking brake cable is seized and I really don't want to cut it and find out that isn't the problem and then go through the hassle to put a new one in.
Any reason WHY they don't go on?
Old 06-03-2010, 09:52 PM
Also my star wheel adjuster is backed down all the way, I've taken the brakes on both sides apart and put them together over 5 times today, still nothing worked.
Old 06-03-2010, 09:56 PM
Also..... my old drums measured 10.090", the ones I bought measure 10.0905" and 10.0901"
Old 06-03-2010, 09:57 PM
A.K.A Bob Dodge
1966sportfury's Avatar
did you make sure they are not hung up on the backing plate? it is a common thing.. i get calls alot and come over to find that the shoe is just hung up
Old 06-03-2010, 10:00 PM
I can't really tell if it's hung up or not, this is my first ever brake job, and I've sliced myself open too much to do anything more today, and after destroying a chunk of my rear I'm pretty aggravated..
Old 06-03-2010, 10:01 PM
Also, when I push one shoe further in, the other just backs away, so they are not butt-up against the pin.
Old 06-03-2010, 10:06 PM
A.K.A Bob Dodge
pull on the shoes slightly then push them together,watch as u oush them together. it sounds like they ar haning up....unless they are a 13" shoe going in a 11" drum
Old 06-03-2010, 10:07 PM
Doesn't seem like it, I matched up the old shoes to the new ones, the match is 100% correct, I've done EVERYTHING I can possibly do to get them to come together, nothing is working
Old 06-03-2010, 10:36 PM
A.K.A Bob Dodge
theres something being missed.. drums are pretty simple.. its not hung up in the adjuster? on top?bottom?the wheel cylinder rods are they hung up.?
A.K.A Bob Dodge
take a few good pic if you can and post them
Old 06-03-2010, 10:38 PM
I'll go out and take pics right this minute.
Old 06-03-2010, 10:57 PM
I got before and after pics, tell me if I did anything wrong, like I said. I went in blind on this and I worked with the pictures I had. This is the passenger side -
From After to Before. http://s955.photobucket.com/albums/ae32/DrownSouls/
Old 06-03-2010, 11:14 PM
A.K.A Bob Dodge
wow all i can see is the rear has to be pulled down and in.. i cannot see the front to well but from the pic its not sittin in far enough (to the center)..i thought pics would help alot.. hopefully someone will see what im missing
Old 06-03-2010, 11:16 PM
I tried pulling and pushing them in, but they just won't move, when I push one in the other moves out, it's getting annoying..
Old 06-03-2010, 11:37 PM
getsum's Avatar
it looks like the parking brake cable may be too tight, the spring looks compressed to much. if its to tight it will push the other side out when u push one side in like u said. make sure the parking brake isnt engaged then look at the cable under the car and see if its hanging loose.
thats my guess from looking at the pics. hope this helps
Old 06-03-2010, 11:39 PM
I might just end up cutting it, who needs a parking brake anyway pssh...
Old 06-03-2010, 11:41 PM
But anyway, my brake isn't engaged.
Old 06-04-2010, 02:57 AM
Looks like they are not sitting properly at the top. Also in picture 5, the shoe on teh right is too far out as you can tell by the retaining pin and spring.
Old 06-04-2010, 03:14 AM
samuelcosmo76's Avatar
......Don't cut the parking brake and not put it back. That would be a mistake. It might come in handy.
Old 06-04-2010, 04:28 AM
sweeperking's Avatar
On page one of your pictures second from the last one you will see a piece of flat stock just under the wheel cylinder. Remove this piece and your drums will fit and you dont have to cut anything. I know I'm probably to late here but thought I would try.
Old 06-04-2010, 06:26 AM
Hmm is that stock piece essential?
Old 06-04-2010, 07:14 AM
Yes as it is part of your e-brake assembaly.
Old 06-04-2010, 07:41 AM
With this piece removed yes it will disable your parking brake but it sounds like your cables are frozen any way. If this is the case and you want your drums to go back on remove this piece. IMO its better than cutting the e-brake cable.
Old 06-04-2010, 08:02 AM
  #24
Well I did it, tires are back on, thanks Sweeper, I wouldn't really need an e-brake for right now, and I really didn't want to cut it
Old 06-04-2010, 09:20 AM
  #25
Why not replace the cables? I'm sure that a store would carry them, if not, then they should be able to get them or something very close to the length that you need. Heck, some shops can even make them.
Old 06-04-2010, 09:51 AM
  #26
I'll replace them when I feel theres a need, but as far as it goes, an automatic with a parking brake is redundant, it'd only be useful if I parked on a hill or slope, which will never happen in this city.
Old 06-04-2010, 10:38 AM
  #27
Although this is a valid point and the cables should be replaced the #1 reason for cables siezing up in the first place is due to lack of use. I cant see putting a new set of cables on the car, never to be used, just to have them sieze.
Old 06-04-2010, 10:56 AM
  #28
While you are right about not needing them with an automatic, you will need them if/when a brake line lets go while you are driving and trying to stop. With the e-brake cables hooked up and adjusted properly, they will allow you to stop.
If you don't ever use them, you can at least set and release them a few times every other month or so and maybe even spray a little bit of oil on them to keep them free.
Old 06-04-2010, 02:01 PM
  #29
X2 on that. Otherwise aim for cheap and soft if your brakes go out....
Old 06-04-2010, 05:12 PM
  #30
blue 68 gts's Avatar
I'm sure I'll get alot of flame for this,
but ALWAYS use an E-brake with ANY car... Always have a good set of lines going to.
That'll suck the day you live it in neutral and take your foot off the brake and hop out.
I always pull on the E-brake handle in the Dart. Its an extra safety feature and a peace of mind to me.
There is a reason ALL cars have an E-brake.
Quick Reply: Drums won't go back on..
