electrical
Old 01-25-2009, 01:24 PM
sgp7679's Avatar
Question electrical
What are some common electrical parts the go out and would cause a car to stall and not restart. I have changed the ballast resistor, electronic ignition,coil,wires and plugs and still no start.
Old 01-25-2009, 03:20 PM
Crazy4Carz.Com's Avatar
Bypass the ignition system. run a wire from the battery to the positive side of the coil. It should run then work backwards from there.
Old 01-25-2009, 07:06 PM
Polaradude's Avatar
I would agree with 66, check for bad grounds and do what Crazy says.
Old 01-25-2009, 08:37 PM
challenger's Avatar
where are you located at sgp
bpatterson
02-04-2009 08:41 PM
64fury
06-17-2008 02:27 AM
64fury
03-09-2008 02:02 PM
TCPMeta
03-28-2007 04:27 AM
Quick Reply: electrical
