How to remove a radio from the dash
Old 01-22-2012, 08:45 PM
Arbiter343GS's Avatar
I have a 1966 Plymouth Fury III and I cant seem to figure out how to remove the radio from the dash because it seems like I would normally just remove the dash fascia and remove the nuts from around the ***** and just push it in and drop it out. But the only problem is, I have A/C and the evaporator box is right beneath where I would pull the radio out from. Does anyone have any ideas? And no Im not cutting the dash or anything to put a new radio in, I just need to take the old radio out so I can clean it out, fix(if needed), and and test it, so I can put it back in and maybe install a new speaker.
Old 01-22-2012, 09:12 PM
You need to remove the transition duct and two spot cooler hoses under the dash.
Remove the electrical plugs and remove the support bracket and it should come out
Old 02-16-2012, 11:03 PM
Im sorry for the late reply, but I havent any time recently to do anything. What exactly is the transition duct and the spot cooler hoses, and how do I remove the transition duct? That may seem like a stupid question but I have never had to mess with A/C systems before.
olibass1
04-22-2011 07:10 AM
64fury
07-12-2009 04:00 PM
66dartvert
04-14-2009 02:16 PM
Quick Reply: How to remove a radio from the dash
